Is there any frame only that's long but not slack?
Steel preferably but aluminium maybe.
19 inch frame or there abouts with a 475 or greater reach but designed for 100-120mm forks
XL chameleon - 486mm reach, not too slack with 120mm fork.
Kona Honzo?
STEEL IS REAL will be doing demos soon.
Killing me as I want a steel 29er before the possible brexit price rises.
What’s slack? Sherpa with 100mm forks isn’t too slack (68deg ish) but may not be long enough?
Genesis Tarn comes close too
Frame you fancy and an angleset ? They give + or - 2 degrees don't they ?
Honzo - can't buy frame only
Sherpa not long enough
Tarn is s good shout but it's forged from solid lead, so heavy when I picked on up
Chameleon - never thought of that.
Honzo – can’t buy frame only
Honzo st available for £750 online, even found a carbon one
Btr or a number of custom builders will do custom geometry depending on budget, if nothing existing fits the bill...
