I'm after a 26" fulcrum rear wheel if anyone's got one knocking about? Red metal preferably.
Jonnyhindley at hotmail dot co dot uk
YGM
Any particular model? I have a pair of Red metal 1's but the front wheel is too buckled to be of much use, replacement rim is not worth it. But the bearings and hub are good, the freehub has new bearings that i put in before realising the front was BER, I was going to put in new bearings in the rear so currently it has none in it, although the wheel is pretty straight it needs a couple of spokes replacing, but with the front you could make one decent wheel. rear or front as required.
