Long Shot : Anyone ...
[Closed] Long Shot : Anyone work for a Ford garage / dealership ?
17 Users
Got a question about rain-sensing windscreen wipers and associated windscreen sensor
TIA
Posted : 24/10/2015 5:07 pm
Ask it.. STW is the font of all knowledge!
Posted : 24/10/2015 5:22 pm
The question he wants to ask is "why!!??"
Posted : 24/10/2015 5:41 pm
Automatic wipers are the best invention ever. Even better than heated seats.
Posted : 24/10/2015 5:43 pm
I pretend I have automatic wipers by simply turning the wipers on when it starts to rain
Posted : 24/10/2015 5:48 pm
I pretend I have the rain sensing wipers from a Ford, by simply leaving my wipers off when it rains.
Posted : 24/10/2015 5:50 pm
Ok, here goes.....
So, I recently bought a Mondeo estate, 62 reg.
Dealer I bought it from (non-Ford) said it has rain sensitive wipers, which was an assumption on his part because it has the rain sensor on the inside of the windscreen, up behind the rear view mirror.
However, it seems that it doesn't have these rain-sensitive wipers after all (don't care really, just curious), only the variable speed intermittent wipers.
So, my question is ......
What the hell is the sensor on the windscreen for then ? eh ? eh ?
Posted : 24/10/2015 6:02 pm
Light sensor? For auto switching headlights
Posted : 24/10/2015 6:08 pm
Nope, doesn't have them either
Nor the auto-dipping rear view mirror thing neither
Posted : 24/10/2015 6:10 pm
Something for the air-con?
Posted : 24/10/2015 6:16 pm
Standard windscreen on all models/trim levels?
Posted : 24/10/2015 6:19 pm
Earth connectors for the heated screen.
Posted : 24/10/2015 6:29 pm
Some times its all fitted bar a single plug in component so when someone ticks the option all the do is add said component and activate it in the diagnostics software. For example some citroen that didn't come with drl's but plug it in and you have them. Ford's without footwell lights some you just need to fit bulbs.
Posted : 24/10/2015 7:03 pm
It doesn't work that well anyway. On the work hack, one click up on the stalk enables the auto wipe, which means it's never quite the right speed or wipes the screen with a sudden light change.
Posted : 24/10/2015 7:06 pm
Mine has got auto sense with a intermittent dial as well.
But you have to have the stark in the one up position.
Posted : 24/10/2015 8:04 pm
Thanks Speshpaul, the intermittent speed wheel actually controls the sensitivity of the auto-sense wipers, if you have them, rather than the intermittent interval if you dont
Posted : 25/10/2015 6:55 am
What model mondeo is it ?
Posted : 25/10/2015 7:23 am
Zetec Business Edition, 1.6 TDCi
Posted : 25/10/2015 7:33 am
My 3 series had it but if it failed it just went back to normal variable intermittent. I think this happens a lot when people put new screen in as the sensor has to be put on the window very carefully with out any dust or anything for it to work. Why not just pop into ford and ask? They will probably have the build info on record. Some features on cars are unlockable but that's usually only if they need to put the equipment or module in for another feature you have. I don't think any car manufacturer is putting that sensor in on a car that doesn't have rain sensing wipers.
Posted : 25/10/2015 8:22 am
[quote=The Wrong Trousers ]Zetec Business Edition
Oooo, get you.
Posted : 25/10/2015 8:28 am
I know, I am an ultra-important super marvellous business executive
Er .....
Posted : 25/10/2015 8:33 am
johnnyboy - I did ask Ford and they confirmed that it was built WITHOUT the auto wipers.
I asked about what the sensor was for in that case, they said they probably just put the wrong windscreen in in the factory !
Somehow, I don't really believe them .....
Posted : 25/10/2015 8:38 am
In my car at least you need to turn the wipers on yourself before the auto thing will take over (as long as its set to auto).
Posted : 25/10/2015 8:39 am
yeah, the idea is that you put the stalk in the intermittent position and if you have auto-wipers, that will switch them on. The slider thing then adjusts the sensitivity to water rather then intermittent interval.
Mine just do the normal intermittent thing.
Posted : 25/10/2015 8:44 am
Pop your reg* or VIN in here http://www.etis.ford.com/vehicleRegSelector.do
...and it will give you a full list of what it came out of the factory with
*doesn't seem to work with Safari, IE OK
Posted : 25/10/2015 8:48 am
https://www.etis.ford.com/
stick your vin number in and it'll tell you what your car spec is.
edit: In the time it took me to remember it wasn't "fortis" - curse you cheese man
Posted : 25/10/2015 8:51 am
yeah, done that, specifies only 'variable intermittent wipers'
Posted : 25/10/2015 9:05 am
