Loctite Recommendat...
[Closed] Loctite Recommendations
8 Users
Hi,
I'm after a recommendation for the best Loctite for securing the pins on my DMR Vault pedals?
Cheers,
Paul
Posted : 12/05/2016 1:00 pm
Posted : 12/05/2016 1:50 pm
I rather like the 248 in a lipstick that Halfords sell
Posted : 12/05/2016 1:55 pm
Low / medium grade is all you need - 248 stick is very handy and little risk of over-doing it
Posted : 12/05/2016 2:04 pm
Another vote for 248 here, very easy to apply, and used for that exact purpose and no pins lost yet.
Used 243 for years previously though with no problems.
Posted : 12/05/2016 2:28 pm
242 would be the best bet as 243 is far stronger than needed, so might cause unwanted issues getting a mashed pin out again. That said, 243 will work and is easily bought, unlike 242 which is much less common... Or 248 as mentioned is also a good option, stronger than needed but easy to use.
Posted : 12/05/2016 5:00 pm
I usually go by the colours for the likes of this,
Pink - weak stuff and normally don't bother
Blue - medium and use it most of the time
Green - strong and depending on the number sometimes needs heat to remove components!
Posted : 12/05/2016 8:16 pm
222 is my go to strength for bike stuff.
Posted : 12/05/2016 8:23 pm
