lightweight long tr...
[Closed] lightweight long travel hardtails. wots yours ?
24 Users
No doubt this topic gets covered regularly, but what does your steed weigh ? I have an orange p7 which has been on a diet since its birthweight was a hefty 31 lb , it now comes in at 26lb with xt transmission, hope hoops and dt swiss forks, easton carbon bits and x2 brakes. I dont think i can take the steel hardtail much further but I like the ride. contemplating either a 130mm carbon or titanium frame that hopefully has similar ride characteristics, I dont do any hardcore riding so dont need anything to burly.
Posted : 03/02/2012 7:20 pm
Mmmbop with Revs and Flow Hoops which is 26lbs... But I've killed the forks and dinged the wheels so I fear for the frame with the way I ride. More burly Replacement has been ordered.
Posted : 03/02/2012 7:24 pm
Been thinking about this question too, but most 140mm hardtail frames are steel. None of the majors seem to make an off the peg bike using an alloy frame without doing an overbuild job on it (Commencal Ramones, etc.). Are there any alloy 140mm frames out there in the Soul/456 sort of mould? Or even full bikes? 25 to 26lbs with 120 to 140mm travel would be nice.
EDIT - I have an old horiz drop-out Chameleon that I run 9 speed and that's probably 27ish pounds.
Posted : 03/02/2012 7:49 pm
Would be interested to know if anyone rides the on one carbon frames, and if theyre durable?
Posted : 03/02/2012 8:14 pm
My Soul is just under 27lbs with Float 140 bolt-thrus, Gravity Dropper, Flows on Pro 2 Evos, Avid Elixirs, 1x9 transmission, flat pedals and big tyres. Nothing has been changed to make it lighter - all just not too expensive, fairly strong/stiff, not too heavy, or what came on my old Boardman HT Pro (bars, cranks, shifter and mech). If your Orange really is 26lbs then a Soul frame would drop up to 2lbs depending on the era of the P7. I'm not sure I'd want to ride a bike much lighter than mine the way I ride it though!
Posted : 03/02/2012 8:24 pm
will report back tomorrow. Finished building this yesterday:
will get first run round Staveley tomorrow. (cables/hoses now tidied!)
Posted : 03/02/2012 8:27 pm
It will be a Canfield yelli screamy with Revs,arches, xtr 1x10,reverb in about 8 weeks.
Posted : 03/02/2012 8:28 pm
Mine @ 25.3lbs
[url= http://farm8.staticflickr.com/7014/6618770011_d0963a8d67_b.jp g" target="_blank">http://farm8.staticflickr.com/7014/6618770011_d0963a8d67_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/17059060@N00/6618770011/ ]P1040284[/url] by [url= http://www.flickr.com/people/17059060@N00/ ]eastham_david[/url], on Flickr
with bont mud x tyres and an I beam post it's 23.4lbs
Posted : 03/02/2012 8:31 pm
I will be interested to hear how the carbon rides. P7 does weight 26lb,granted I have lighter wheel/tyres than some would run, crests and nobbly nicks. weighed on reuben heaton spring ballance back from my fishing days.
Posted : 03/02/2012 8:34 pm
I have a 2012 cannondale flash ultimate with a set of carbon tubulars for dry sunny races, weight not sure not been weighed yet
Posted : 03/02/2012 8:44 pm
oops just realised the thread title ..... 😳
Posted : 03/02/2012 8:45 pm
Not long travel though is it...
Posted : 03/02/2012 8:49 pm
my bro has a scott carbon roadbike and we weighed it at 17lb , tho that hasnt a great deal of travel either.!
Posted : 03/02/2012 8:53 pm
I have one of the first Shands ever built, w/130mm...does that count?
Posted : 03/02/2012 8:55 pm
Awesome. But this isnt a thread for heavy weight road bikes!
Carbon 456...
[url= http://farm4.staticflickr.com/3295/5864551398_6d35d62763_b.jp g" target="_blank">http://farm4.staticflickr.com/3295/5864551398_6d35d62763_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/53860438@N06/5864551398/ ]Shiny[/url] by [url= http://www.flickr.com/people/53860438@N06/ ]Northwindlowlander[/url], on Flickr
Had a few changes since then but still basically the same- 25lbs with fat tyres and a gravity dropper. Nothing too delicate on it. That's actual 25lbs btw, not internet 25lbs 😉
I really like it fwiw... Has a bit of compliance to the rear end, and I've stuck a slackening headset in it, so it's ended up with most of the best bits of my old Soul and Mmmbop, with none of the vices. Does feel a bit long, and doesn't climb as well as either of those 2 for some reason, but that's fair enough. Not perfect but still very good.
Posted : 03/02/2012 11:33 pm
[url= http://farm8.staticflickr.com/7154/6770127497_2ddd9ba93c.jp g" target="_blank">http://farm8.staticflickr.com/7154/6770127497_2ddd9ba93c.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/55902740@N06/6770127497/ ]IMG_4821[/url] by [url= http://www.flickr.com/people/55902740@N06/ ]ps6175[/url], on Flickr
Current ltht of choice about 27.5 at the moment could could easily be slimmed
Posted : 03/02/2012 11:54 pm
Thread hijack-sorry
Vortexracing. I have a Soul very similar to yours (but orange)
Currently only has a top chainguide (Superstar), dropping the chain a lot and so need to have a bottom guide as well. I have a Superstar top and bottom guide on another bike that works perfectly, never drops a chain but noisy on the bottom jockey wheel and did not want this on the Soul.
You seem to have an MRP top and bottom guide on yours, is that noisy?
Posted : 04/02/2012 12:08 am
 mboy
Currently about 24.5lb when devoid of waterbottles and anything else I've strapped to the frame. When first built up, it was 23.3lb, but had Carbon bars and 9spd XTR not 10spd XT (which is quite a bit heavier) and lighter tyres. Though I'm sure if I slung my Mud X's on it'll dip back under 24lb.
Again, these are actual weights, not internet made up weights. And they include the pedals too! Here's a pic of the bike when it was just built, coming in at 23.3lb...
Ironically the Bolt through Reba's are slightly heavier than the QR Revelations they replaced, though stiffer, and I added more weight with the chain device as well as with the 10spd XT stuff and Alloy Sunline bars to replace the Carbon Eastons.
Posted : 04/02/2012 12:17 am
 mboy
Thread hijack-sorry
I'll weigh in as I have done the same, and now run the same MRP Lopes device as Vortexracing. The MRP Lopes isn't silent, but it's a lot quieter than most chain devices. It's also a country mile better for chain retention than the Superstar top only guide (but then so is everything else!).
Decent Chain Devices are silly expensive when you look at them on paper, but the old addage "buy cheap, buy twice" seems to apply here as every cheap chain device I've ever used has either been really noisy, or won't keep the chain on, or both!
Posted : 04/02/2012 12:21 am
As mboy syas, not perfectly silent, but not that noisy that I notice it TBH.
daft money for what they are though.
yip, I would recommend one.
Posted : 04/02/2012 6:58 am
My MmmBop, around about 27.5lbs
Posted : 04/02/2012 8:04 am
 hora
Mboy what genesis model is it? Can't see on my blackberry
Posted : 04/02/2012 8:58 am
 br
I've a 456Ti, basically bought after riding a steel 456 and wanting to loose more weight but didn't want the stiffness of an aluminium frame.
tbh If it'd been now I'd have just bought one of the carbon 456's.
Weight could be sub 24lbs for a 20" - full XTR, Crests, carbon etc - but once Cruds, light-brackets etc are added its now sub 25lbs (Park scales).
Posted : 04/02/2012 10:20 am
hora I'm pretty sure that's the Altitude Ti
northwind - what's your spec? my c456 was 26lbs dead with similar bits but no dropper post.
Posted : 04/02/2012 10:53 am
Ti456 with 130mm fork:
Comes in at just over 24 lbs, but I like the level of kit on it (XT, Hope ProII's on Crests) - nothing too flimsy. 🙂
Posted : 04/02/2012 11:01 am
Medium Soda with '07 Revs at 130mm, Hope Pro IIs on Crests, mostly XT drivetrain. I guess around 25lbs, but I've not got round to weighing it. Or taking a decent pic, so you'll just have to imagine it...
Posted : 04/02/2012 12:28 pm
Just weighed mine out of interest thinking its probably under 30lbs but its actually around 31lbs. Not too bad considering the build.
Posted : 04/02/2012 12:43 pm
chakaping - Member
Just light-but-strong throughout... Rev Teams, Roval Traversee wheels, XTR cranks, easton bars, MG1-ti pedals, renthal kevlar grips, X9 drivetrain, charge knife saddle, oro brakes with R1 rotors, and a sprinkling of titanium bolts. Oh and a foldy Nevegal and Nobby Nic run tubeless.
Right now it's lighter though as my Revelations blew up again 🙁 So now it's an overweight rigid.
Posted : 04/02/2012 12:56 pm
mboy and vortexracing. Thanks, will probably have to take the plunge. just didn't want to spend £100 and find it was no good. Cheers.
Posted : 04/02/2012 8:30 pm
use a CRC voucher and buy it through Topcashback, that should save about £13
Posted : 04/02/2012 8:36 pm
Use an LG1+ on my 1x10 mmmbop. Sometimes wonder if it's overkill but It works a treat and i never have any problems with the chain.
Posted : 04/02/2012 8:51 pm
My kinesis maxlite xc120 comes in around 27lb with coil revs, lx groupset and 317 rims. Would be easy to make it light, the frames only 1500g
Posted : 04/02/2012 8:59 pm
 br
[i] I guess around 25lbs, but I've not got round to weighing it.[/i]
Posted : 04/02/2012 9:53 pm
