I'm going to the Alps in September, and whilst training and trying to lose some weight will be way more effective I'd rather buy some additional speed, so I'm going to throw together some cheap, light road wheels.
Going to get some Novatec hubs, but what rims? Want <400g ideally. Wheels are disc, but not particularly bothered about disc specific (as long as they come in 28h), so thinking of some Alpha 340s, there's BOR 373 Discs, what else am I missing? Will be 25c tyres at 90-100psi, likely with tubes, but not averse to tubeless (if I got the Alphas).
Totally going to be worth it for the 3 seconds I save on the Galibier.
I have the alpha 400's but in 32 hole and they've never skipped a beat, nice set up tubeless too.
Yes I've got a set of Alpha 400s I bought because they were the same ERD as some Bontrager RXLs and it meant I could keep the hubs, they've been good, heavier though.
I'm imagining 340s to be flexier. I've seen some built wheels using 340s without the machined brake track which look good, all black, presume that's an OEM rim or DIY though.
Kinlin knock out some lightweight clinchers.
Dcrwheels do a 405g disc one. Welded joint, thicker spoke bed and tubeless ready. Not sure where he sources them from.
Kinlin if you want really lightweight.
DT Swiss RR411 DB (disc brake) bicycle road rim
£65.00
https://thecycleclinic.co.uk/collections/rims/products/dt-swiss-rr411-db-disc-brake-bicycle-road-rim
Stans 340 for the front and 400's for the rear.
out of interest which novatech 28hole disc hubs ? Alex black dragon rims were available from rose bikes at less than £10 each! (maybe too portly for road at around 500g each but ideal for rough cx)
Was going to use the D411/412 straight pull ones. They look pimp, and are respectably light (320g) for the price (£90/pair).
Hadn't thought of Kinlin. DT an option, slightly more portly, known quantity though. DCR wheels sounds interesting, will check them out.
Ive had a few alpha 340s and for me they are fine but I I'd don't have huge power and weigh 60kg
The all black alphas used to be a normal stock item from stans but not looked lately
Not sure I'd go much under 400g for an aluminium rim. If I wanted lighter i'd go carbon. You can't be that worried about weight riding a disc brake bike though 😉
Ho ho ho! No, I'm not, I've got a much lighter rim brake bike, which I was going to take, but if it's wet I know lll just think "wish I'd brought the disc bike", particularly with carbon clinchers. And I like buying stuff, I reckon sub 1400g and £250 can be done.
You don't really seem to get much lighter carbon clinchers, and I CBA to go tubs as I may sell the wheels on in 2 months and I suspect tubs will have a much lower resale value. Obviously I've looked as some 250g rims is tempting!
Those DCR ones look good, probably leading the way at the mo.
I'm on 340s, I used spoke nioples in the rear as I was concerned re them being a bit weak, but they are fine. 32H and I'm 70-75kg.
Washers not nipples. The nipples pulled through the rim when I left them after a few rides on salted roads.
Crikey, not great, guess the spoke beds are very thin though.
Njee,
Did you build up a wheelset?
I have some Novatec hubs that got delivered today, I plumped for the DT rims as I'm intrigued by road tubeless, could get them easily at trade price and they're a known quantity. Once I've measured up I'll get some DT Competition Race spokes on order.
So... no, but I will have soon enough.
Also suspect that 1400g is out, but be pleased with sub 1500g. 1400g doable with Aerolites and skinnier rims.
The hubs were waiting when I got home yesterday, look good!
322g for the pair (1g less than claimed), for £102 delivered I'm chuffed.
Spent the evening measuring up the hubs for spoke lengths, remains to be seen if I got it right, never actually built SP wheels before. Hopefully have them done sometime next week. DT Spoke Calc reckons 1422g for the pair, I think that's optimistic. Reckoning on 1475g.
I'm not an engineer, but aren't disc rims designed to cope with the braking forces being transferred from the hub to the rim?
I've got Alpha 340 (the original fragile ones) on ebay hubs (288g/pair, think they're novtec).
They seem to be holding up so far. Although the new speed bumps at the bottom of the hill in Windsor Park are F***ing vicious and I let a little poo out every time I hit them.
I'm 98 kg though, if I believed the weight limit on the newer/heavier ones I should be fearing for my life just in a straight line!
Stiffness wise, they're not stiff, but I can't get them to rub the brake pads even out of the saddle. I did wonder if that's a sign they're so flexy that the strain induced in the lower half isn't transferred to the top half (as would happen with a stiff rim in a poorly built wheel).
I think they weigh about 1250g and I'm commuting on them, mostly to get some use out of them before I bite the bullet and have to build some 11s wheels.
More likely the other way around, a rim brake rim has to resist the crushing force, the force from a disk brake wouldn't be vastly outside what you'd expect the spokes to experience normally, it just redistributes it from even spoke tension to greater tensioning the 'pushing' spokes. Disk rims are usually much lighter, e.g. Stans Crest MTB rim is much lighter than most road rims.
Njee, where did you get your hubs? I'm looking at some point for new wheels but will be using normal spokes. I've been impressed so far by my novatec on my full suss
I'm very 'meh' on all of that, but as per TINAS's comment I suspect a rim brake rim is likely to be tougher. Moot point as I went with the DT disc specific ones anyway, which do look better.
From AliExpress, seller was called DeerCycleCarbonWheels, they only listed 24h, but may have others if you want more. I paid £5 extra for postage and they arrived impressively quickly.
Found Bike24 were doing Schwalbe Pro One Tubeless tyres for €33 each too, seemed rude not to give them a go.
I've got some almost new Aksiums I'll be Ebaying next week.
Ahh yes, those 2kg 'lightweight' wheels... 😕
Cheers njee, I'll have a look
Specifically, [url= https://www.aliexpress.com/store/product/323g-Only-LIGHTEST-NOVATEC-CENTER-CENTRE-LOCK-ROAD-DISC-STRAIGHT-PULL-BICYCLE-HUBS-D411SB-CL-D412SB/1081104_32820492929.html?spm=2114.12010612.0.0.3f050b0b2EU8bP ]here[/url]. The Centerlock ones were harder to come by (if you're bothered by such things), loads of sellers doing the 6-bolt ones, many advertise them as 15x100mm front (I wanted 12x100mm), I did message another seller who said they could supply a pair of 6 bolt 28h ones as 12x100 even though that wasn't advertised.
Kinlin rims:
I've got some Kinlin XR 200 rims with CX Ray spokes and Bitex hubs (20h front, 24h rear). I think they weigh around 1250-1300g for the pair (no skewers)
However, they are total guff - the spokes snap, the wheels go out of true all the time. Same with two sets of spokes now. (under my vast 65kg bulk I should add).
CX rays are good so there is a problem somewhere related to the hub or rim, or some sort of combination issue.
A glowing review indeed! I'll consider those a bullet dodged.
Have you tried rebuilding them?
My 340's were horrible the first time I rode them. Took them apart and rebuilt them, still horrible, 3rd time I really took my time, brought them upto tension 1/4 turn at a time keeping them true the whole way from nothing and they've been faultless ever since.
The first two were still perfectly true, and had even tension, but clearly something was wrong somewhere.
I should have said I didn't build them. They came with Pillar spokes which kept on breaking - so I took them to a good wheel builder who rebuilt with with the CX rays - and the exact same thing is/was happening: Quickly out of true and then a spoke snaps (n.b. no big hits etc.)
I had thought about a rebuild but given that it's not clear what was actually wrong with them I bought some 2nd hand R-SYS instead.
Find a new wheel builder next time?
That's a seriously low spoke count for such a shallow section lightweight rim
Pretty normal on road wheels though. Be a bit odd to get super light rims and then build with 32 spokes!
Both my rim braked road bikes are 20/24.
I guess with discs you won't hear the brake track rubbing on the blocks when it flexes under MAX POWER riding up them Alps 😉
Where did you get the rims from?
Let me know what they are like to build.
Thanks
Not much risk of me flexing any wheels given my current fitness!
Got the rims from my LBS, they look good. They include the squorx nipples which I won't be using, got normal 12mm alu in stock.
As was I. However trying to get the bloody tyre to seat is driving me insane. Currently got a tube in there and will leave it for a few days and see if it helps.
Have you had a go at "another wrap of tape and try again"? Works for me 9/10 times if a tyre won't seat, even with an Airshot. I find that old tape sits down in the well of the rim and the bead snags on it. A new layer of tape seems to facilitate the bead popping over to the rim and locking in there.
Hmm might give that a go. Rims came pre taped. Bead just seems to sit in the well and won't budge even with loads of soapiness.
Are they a tight fit? (Sorry OP to hiijack!)
Very tight but can get them on and off with levers and a bit of faff. I got the DCR rims and trying to fit Schwalbe Pro One. Got an airshot style inflator but can't get the bead anywhere near the rim.
Well, last word on this to let the thread get back to the original topic (!) but I'd try another wrap of tape. Also make sure the valve isn't interfering with the bead and peeing air out there as well... Good luck!
Hijack away, this is all very relevant! I've got a Bontrager whatsit tubeless pump, which I'm hoping will be ok...
Njee will probably be thankful for your posts in a few days time 🙂
Indeed I will! Shall keep the thread updated on my progress. Building straight pull wheels with round spokes will be the first challenge, can't even use my slotted bit of wood to hold them still!
If it helps.. my schwalbe pro ones tl easy went up perfectly on superstar arc22 rims. No tyre levers involved and went up first time with a tubeless inflator. Didn't even need to seat the bead with a tube first either.
So far I'm loving tubeless road.
The thing is I've had tyres go on easy a few times too but it totally depends on the tyre/rim combo. And if they're tight, they're [i]tight[/i], and it's not the user's fault or lack of skillz or whatever, it's just a fact of the physical dimensions of the two components. eg. Schwalbe Ones onto A23: easy. IRC RBCC onto Pacenti SL23: snap tyre lever and willing to believe it is simply impossible to get the swines even over the rim to begin thinking about seating!
YMMV obviously but while I do totally love road tubeless and bang on about it to my riding buddies, I have always told them I wouldn't actively recommend it to them unless they were prepared for some potential serious faff that may or may not materialise 😉 I'm sure those who happen to have a decent combination would feel differently and say it's a piece of cake but having seen both sides it can be pretty damn frustrating!
I had the same when rebuilding some old Roval road wheels.
I ended up using some sprung mini plyers with gorilla tape in the jaws to grip the spoke before it was tensioned.
I also found tightening the nipples from the tyre bed side easier.
Is there some reason why you can't do the tried-and-tested way of overshooting by half a turn then backing off to avoid wind up? Always worked for me even with thin spokes like Sapim Lasers. I haven't read every post so don't know if you are using some sort of fancy nips...
Theres a lot of faffing expressed on our club website about sealing those tyres tubeless, and their relative fragility, worse still should you need to unseat then again and insert a tube out on the road.
The answer seems to be Vittoria tubeless.
Not sure how they are relatively fragile? Compared to a standard clincher they seem more armoured than anything, hence why they are usually heavier. It is true however that you may end up leaving a tubeless tyre on for a perhaps-perceived less amount of time/distance because there comes a point where you look at it and go "if that punctures I'm not sure it'll hold" due to nicks and cuts whatever, whereas with a clincher you'd probably just stick a new tube in and carry on.
After the first couple of nervous tubeless rides, I've never even bothered taking a tube with me and apart from one incident that would've killed any tyre I've never had a problem in over 20,000km on tubeless. A few spurts here and there where something's pierced and then re-sealed with no pressure loss which is always a heart-stopping moment but apart from that I am truly angering the puncture gods and will pay for this next time out 😉
Each to their own though, non-believers are generally very skeptical but I wouldn't go back.
Not so much wind up - there's nothing to just stop the spoke endlessly spinning. Sure it'll be fine.
Mildly nervous about the idea of insanely tight tyres now, perhaps the cheap Schwalbes were a clue!
Ah because they're straight pull aren't they... Knew I must've been missing something apologies. Never built with them but presume once you've got a little bit of tension in there they will bite onto the hub spoke hole sufficiently to stop spinning?
I vaguely recall you're near Reading MrBlobby? Seem to remember you mentioning TT's on the A33. If you want to try inflating them with my compressor drop me an e-mail, I'm only in Three Mile Cross.
I'm hoping so! I've rebuilt straight pull wheels before, but always bladed, so you just hold the spoke still. I'll be going for the pliers and electrical tape method, sure it'll be fine. I'm expecting a bit of wind up in Competition Race spokes, but don't think it'll cause problems. They're great value, same price as Competitions, but virtually the weight of Revs.
Good idea - or at least someone who will say to me: "what you are trying to achieve, with the bits you have, and your budget - is a waste of time"
N.b. I bought the rims, old spokes and hubs myself (as compete wheels) on the cheap from China in an attempt to get strong (enough)-light-cheap. And as usual, it didn't work. I'm reluctant to blame anyone else for my total idiocy!
At some point I may try again and try and fix the issue - but at least I've got wheels that work now.
Have I missed something in this thread - I thought straight pull with disks was a no-no??
The spoke will grab eventually but hold the spoke close to the rim on the inside and tighten from the top.
I use the park SW-15 or a screwdriver with a V cut into it to get them started.
You're probably thinking of radial lacing, rather than straight pull spokes, of which there are many off-the-shelf disc options around.
straight pull spokes/hub (but still crossed lacing) - fine for disc brakes
[img]
[/img]
radial lacing (with j-bend spokes) - bad idea with disc brakes
[img]
[/img]
radial lacing (with straight pull spokes) - also bad idea with disc brakes
[img]
[/img]
Yep, as Amedias says, lots of SP disc options - Hope, DT, Novatec etc all do SP hubs. Plus many factory wheels too.
Thanks, I've got a Park ND-1, so should be alright.
Thanks TINAS. Got an offer of using the compressor at LBS but if I need a compressor to seat a tyre then I won't be sticking with road tubeless.
Threw them together tonight, 1433g actual weight. Pretty chuffed with that given rims were actually 418g each, so hardly featherweight. Hopefully a decent all round wheel set though, rather than silly light. £250 all in.
Need to do final tension and true tomorrow, went together nicely though, had to re-lace the rear; asymmetric rim means shorter spokes on the DS, whilst front is same both sides, that'll teach me to assume!
Will take some pics shortly.
Got the tyres on and seated yet?
That's really light.
My Kings on 28h Grails are 1.7kg. Given the difference in hub weight is only 130g and the rims are, what? 70g (total)? Makes you wonder where the rest is hiding in my wheels.
njee20 well done. how did you calculate spoke lengths? Spoke calculator dont do striaght pull spoke normally. to work it out you normally have to do a cad drawing which is a PITA or guess (I can guess right). do you have another way.
To the stand grail rider your rims are heavier than the DT Swiss RR411's and your spoke may be heavier. brass nipples if used also add weight over alloy. The weight will be somewhere. The CK R45 disc hubs are also quite heavy for what they cost @440g/pair.
To the guy with the Kinlin XR200 rims and bitex hubs. your wheels fail because they are not stiff enough. when I built with the XR200 and I still do sometimes I do a 28 spoke minimum and stipulate a max rider weight of 80kg. A 24 spoke rear (I did one once for a youth racer) was too flexy and never built it again. the young rider was very light so not an issue. reuse the hubs but on stiffer rims like the Kinlin XR31T/RT.
Munkster the IRC/Pacenti combo is tight but doable. I have tyre levers that make it possible. it is tighter than the Kinlin IRC combo though but they do seat and seal with compressed air. The kinlin IRC or schwalbe combo is so easy it is a doddle (track pump is all that is needed) and they way it should be.
Th point of road tubeless is they should not unseat when the tyre is at low pressure allowing to to ride still. If they unseat then that is a problem only solved with CO2. Also the tyre can be fixed at the road side externally with worms and flexible superglue. I would never advise putting a tube in at the side of the road as it faff and not necessary. pretty much all but the biggest slash (which require a new tyre anyway) can be fixed quickly even if it holds only 40 psi max to get you home.
Also from testing stans sealant is hopeless for road tubeless. fine in #MTB tyres but at road pressure it fails. Effetto mariposa or orange seal are the best. I use effetto mariposa only now. it has not failed me yet. It also seems that some selants work better with some tyres than others. i have noticed the effetto sealant can sela bigger holes in the IRC tyres than it can in the schwalbes. I have no idea why.
The only issue with tubeless is the learning curve you have to go through. I have put a guide of the shop website and I know it works.
DT spoke calc does straight pull hubs, handy I was using their rims too, I wouldn't have factored the asymmetric spoke bed otherwise. Didn't actually measure the hub offset, just guessed it would be the same as a DT240 (or close enough so as not to make a difference), just measured flange widths.
I used alu nips, and only 24 spokes. The DT Competition Race is nice, barely heavier than the Revolution and only €0.90 in straight pull guise.
Ah, that explains the difference. 8 spokes and brass nipples.
njee, done the tubeless thing yet?
I got the front done here. Needed stretching (or at least shaping) with a tube in it for a few days. Then found that the depressed tape in the offset holes in the spoke bed was allowing the air to blow out past the side of the bead when trying to inflate. A wrap of gorilla tape did the job and that's now seated and sealed.
Tried the rear without having had a tube in for a while and can get it partially inflated but won't hold much air past 40psi as it's not seated properly. Again just seems too tight and will pop in part way around but not all the way, resulting in a lumpy wheel. I'll let it sit with a tyre in for a while before i try again.
It's been a huge PITA in comparison to off-road tubeless.
How far did you inflate it? I sometimes find I have to inflate past the "recommended" pressure (eg 120 or whatever) to get the tyre to properly seat first time round. Obviously at your own risk, no guarantee etc etc. IME if you've got it to seat mostly/somewhere around the rim you're way over halfway there and it'll seat eventually with a bit of oomph. YMMV as above.
Yup, 120 psi. Didn't really want to go much further. I'll leave it like that for a day or two, deflate and try again.
That was me. Thanks for the advice and diagnosis, kind of what I thought!
Njee20: If it's not taking a liberty (it is a bit...) would you be able to post up a spec list (incl. spoke lengths) you used. Might copy your build....
Sure:
Rims are DT RR411 DB available from your friendly LBS.
Spokes are DT Competition Race straight pull 298/298 on the front and 298/296 on the rear. I bought from Bike24, they came very quickly.
I used normal 12mm alu nips, using the washers included with the rims. Mainly because I had the nipples in stock, and didn't want to buy the tool to use the 'Squorx' nipples they include with the rim.
Only weird thing was that I built them in the logical (to me) orientation of the rim - with the offset 'reversed' on the rear (so wide bit facing the non-disc side on the front and the disc side on the rear, but when I put some tension in the rear the dishing was about 10mm out, and it was going to end up with insane tension on the drive side to get it back. I rebuilt the rear with the offset the other way, so both rims have the 'wide bit' of the spoke bed on the RH side and they were spot on. Have to see how they feel, tension is pretty even.
Used a wrap of Stan's 12mm tape which didn't really cover the spoke holes that well as they're so far offset, covered with a layer of insulation tape. Schwalbe Pro Ones went on (they're tight, but not insanely so) and went up perfectly, using a Flash Charger, but I think they'd have gone with a normal track pump. Not ridden them yet, but they went together nicely (issues about offsets notwithstanding) and feel pretty solid. They're not my finest work, but hopefully won't fall apart!
[url= https://farm5.staticflickr.com/4408/35689679793_548f123aa7_z.jp g" target="_blank">https://farm5.staticflickr.com/4408/35689679793_548f123aa7_z.jp g"/> [/img][/url][url= https://flic.kr/p/WnLWoM ]Untitled[/url] by [url= https://www.flickr.com/photos/46244709@N04/ ]njee20[/url], on Flickr
[url= https://farm5.staticflickr.com/4437/36361001851_60999d5d66_z.jp g" target="_blank">https://farm5.staticflickr.com/4437/36361001851_60999d5d66_z.jp g"/> [/img][/url][url= https://flic.kr/p/Xp6D42 ]Untitled[/url] by [url= https://www.flickr.com/photos/46244709@N04/ ]njee20[/url], on Flickr
Tyres seem to be losing air over the course of a few hours - from 90psi to c50psi in 6 hours or so. I'm assuming that riding them will seal all the little pores and that, at the moment that's obviously not ideal!
Nice.
I'm about done with tubeless. Front is ok. Rear, I can now get the tyre to inflate tubeless but too tight to seat properly all the way around (I can't even get the Pro One's to seat evenly with a tube in) and leaks air badly between bead and rim. I think I've probably wasted more time on this than I've ever spent changing tubes in the entirely of my cycling life!
Cheers Njee!
Mmm, I'm worried that it solves a problem that never existed for me. I've never had an issue with tubes, I don't flat often, I don't want to run low pressures.
I'd have used the wheels to commute on yesterday but I wasn't confident they'd still have enough air in them at the end of the day to ride home! We shall see, I'll give it a go, but can see me reverting to tubes!
Certainly the case for me. I'm regretting having ever started down the path.
I kinda figured it's only cost me a pair of tyres, and I can probably flog those for close to what I paid, so no huge issue.
Njee, how have you got on with the rims?
Can you recommend them?
Just about to sort my build out.
Thanks
Holy thread resurrection Batman!
Sorry, just searched out this thread for an unrelated purpose and saw your question.
They were alright, I ended up buying 'proper' tubeless tape, as the front kept slowly leaking, after which the tyres were perfect. I took them to the Alps, which is why I bought them ultimately and they were good. Made weird pinging noises while climbing, unsure if it was flex, or dodgy tensions or what. Did about 800 miles on them all in, and then sold them. They were still true, the dishing was still slightly odd on the rear, not 100% convinced by the DT spoke lengths. I'm sure they helped when riding up Alps (even if it was psychological, I'll take that), but they looked silly on my aero bike, I have a much lighter bike to ride in the UK when I'm not worried about cooking rims on the way down.
It was basically a cost neutral exercise though, about £15 net cost, so if I went back to the Alps I'd probably build another identical set!
