Lighting for garage...
[Closed] Lighting for garage with no mains
22 Users
Any suggestions.
Thinking of a big led set that i can mains charge.
Poss using a car battery
Anyone done this, or seen something sensible.
No mains in garage but it is only 2 mins walk away so can carry a car battery from home..
J.
Posted : 19/08/2014 10:06 pm
I have no suggestions, only sympathy. My garage has light, but nothing else and it's pissing annoying. I'm moving house next week and a powered garage is genuinely the thing I'm looking forward to the most.
I will be able to charge my lights / garmin / phone
I'll have proper lighting rather than one solitary 60W bulb (in the middle so it casts a shadow on EVERYTHING)
I will be able to listen to music
I'll be able to use a compressor
I'll be able to use power tools
Is this helping?
Posted : 19/08/2014 10:17 pm
How big is the garage? Would have thought LED tube lighting would be your best bet - maybe 3x T8's would do a single garage? 3 5ft tubes 66w, which would give you 16hours light on a 90ah leisure battery I think...?
If you keep it all 12v and don't need proper power then solar chargers on the roof? Or what about rigging an alternator to a turbo... 😆
Posted : 19/08/2014 10:33 pm
LED easy peasy.
I used 2m of Labcraft stuff in my van and it was ambulance style bright. Also used for working light in a massive building recently and it was acceptable. The tape was stuck in aluminum C shaped extrusion to increase robustness or you can get the labcraft style stuff from caravan suppliers.
Posted : 20/08/2014 12:03 am
You can buy rechargeable work lamps cheap enough these days...I wouldn't be fighting on with car batteries.
Posted : 20/08/2014 12:21 am
Just buy a shed lighting kit from ledhut.
External solar panel
Internal lights and battery - 5 m cable.
I had an early incarnation of it in my garage pre led technology.
Much easier than pissing about with car batteries
Posted : 20/08/2014 12:56 am
Thanks guys.
Lots of things for me to investigate.
It is not my garage/ on my property so the solar thing may not be ideal, but will try and make it work as that seems the best solution.
Posted : 20/08/2014 9:14 pm
I reckon something like this would do
http://www.screwfix.com/p/ae0183-rechargeable-led-work-light-10w-12-240v/1815d
Posted : 20/08/2014 9:19 pm
Thanks stoner,
Very interesting..
Posted : 20/08/2014 9:54 pm
 m360
Coleman Nightstar lantern 8)
Posted : 21/08/2014 7:38 am
Glow sticks.
Posted : 21/08/2014 8:07 am
Solar panel?
Posted : 21/08/2014 8:08 am
Buy a small generator.
Posted : 21/08/2014 8:09 am
[url= http://www.ebay.co.uk/itm/290986287253?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 ][/url]
These are great, really good spread with no hotspots.
Posted : 21/08/2014 9:08 am
Years ago I had a car battery hooked up to a car foglight, with a switch. Lasted for quite a while and just needed charged every so often.
Posted : 21/08/2014 10:32 am
Those Screwfix worklights were on offer the other week (20 something quid) keep an eye out I'm sure they'll be on again.
Posted : 21/08/2014 10:54 am
The light of Earendil? Great for scaring off the big spidees hiding in the dark corners too 😉
Posted : 21/08/2014 11:03 am
I've ordered a shed lighting kit from LED hut (£13) (thanks trail_rat) for my shed as it goes as that's pitch black inside and I don't want the hassle of running power to it if I don't need to - I'll let you know how it goes.
Posted : 21/08/2014 11:05 am
Those screwfix [url= http://www.screwfix.com/p/ae0183-rechargeable-led-work-light-10w-12-240v/1815d ]battery worklights[/url] are really bright but not very diffuse so they are not good for detail work in the confined spaces of a garage. Plus, the battery doesn't last more than 3hrs.
I found it doable to use one of those plus a bike light and a head torch when I worked on my mx bike in a garage.
Posted : 21/08/2014 11:53 am
I'm about to build a solar panel from cheap broken cells and rig it up to a leisure battery.
More of a fun project with my son than one that has to succeed, but I'll let you know how it goes.
It'll be a fair few hours work though.
These are the cells I bought:
http://www.ebay.co.uk/itm/400gr-6x6-polycrystalline-broken-solar-cells-about-160w-solar-power-/371030406106?pt=UK_Gadgets&hash=item566322b3da
There are loads of howto videos on youtube.
Posted : 21/08/2014 12:19 pm
Superficial - Member
Hopefully moving into new place next month, proper garage, with light, power, shelving, the lot. I even have a couch to put in it, and a stereo. ight even locate a wee fridge.
Going to get the tools up on the wall too, what are folks using for that? Pegboard?
Posted : 21/08/2014 12:22 pm
Just eat more carrots.
Posted : 21/08/2014 12:26 pm
Pegboard?
I found that the retail world has abandoned pegboard, so it's not as easy to get fittings as it once was. I kept finding links lead me to the US 🙁
They use slatboard instead which doesn't allow for as dense a layout.
Still trying to work out what to use instead.
Posted : 21/08/2014 12:30 pm
Thanks for input.
I went with a big pot of radium paint in the end.
Added benefit is that I continue to glow after leaving the garage..
Posted : 21/08/2014 12:37 pm
Ikea magnetic knife racks for me
Posted : 21/08/2014 12:41 pm
Got a link for that shed kit nemesis (or trail rat)
Im using a tilley and its a bit of a faff
Posted : 21/08/2014 12:43 pm
Here you go - it's not going to be mega bright by my reckoning but it's enough for what I need (just finding things in the shed basically)
http://www.ledhut.co.uk/solar-flood-light-pir-80-lumens.html
Posted : 21/08/2014 12:44 pm
AlexSimon - Member
Right - drawing similar blanks here just now.
Want to draw the outlines of them, etc. A sheet of ply with nails should do just fine though.
Ta mate, that'll be ideal. If ive got much to do I use the ginormous extension lead for light and power but for just general rummaging will be fine.
Posted : 21/08/2014 12:56 pm
General rummaging is usually lit buy a computer screen, no?
Posted : 21/08/2014 1:04 pm
bottle light?
[url] http://www.bbc.co.uk/news/magazine-23536914 [/url]
Posted : 21/08/2014 1:20 pm
Funnily enough I did consider that - problem is that they obviously only work during the day (and really only when it's reasonably sunny)
Posted : 21/08/2014 1:22 pm
fair do's, I just love the idea.
Posted : 21/08/2014 1:38 pm
Also, cutting a hole in your roof is only a good idea in a dryish country.
Posted : 21/08/2014 3:05 pm
They do use sealant afterwards...
Posted : 21/08/2014 3:06 pm
Just as a followup, I got the solar charge light [url= http://www.ledhut.co.uk/solar-flood-light-pir-80-lumens.html ]I linked above[/url] and it seems to do the job well - it's easy to mount and plenty bright enough for my shed. I wouldn't want to be doing fiddly bike work with it but then that's not what I got it for.
Posted : 27/08/2014 1:30 pm
