Lifeline Pro truing...
[Closed] Lifeline Pro truing stand.... thumbs up
4 Users
This one
Bought one a few weeks ago and used for the first time today. Apart from the fact the adjustable arm was set off centre as it came (easily rectified) I am very impressed. It's not as bang on accurate (or as heavy) as the Park pro workshop one, but it is well under half the price and for a home mechanic it is perfect. I'll be using it to check the wheels on my Scandal before I sell it. I can't recommend it highly enough as part of a garage tool kit. Thanks Lifeline 😊
Posted : 16/08/2021 7:44 pm
Like some the CRC reviews, mine arrived with the uprights not perpendicular to the alignment arm. Means I'd have to realign for every wheelsize.
Thumbs down from me.
Posted : 16/08/2021 7:49 pm
Did you adjust the alignment arm to centre it? That's what I had to do. Once that was done it was fine
Posted : 16/08/2021 7:52 pm
I can center it to the axle clamps at closed position. If I then extrapolate that out to a 24" wheel I then have to center it again.. same for 26, 27.5 and 29. Same size wheel with a 100qr vs a boost rear would also result in a different angle as the misalignment is more pronounced at the closed position.
So, for each wheelsize I'm working on I'd have needed a known properly dished wheel.. or build a jig to align the stand to each wheelsize and hub size.
https://ibb.co/Zzdv6B4
I guess a quick check would be to set (center) the calipers to a wheel then flip the wheel around. See if its still aligned to the calipers.
Posted : 16/08/2021 8:40 pm
Heres a visual of the issue I believe I have in my case (not scaled).
green = caliper alignment axis and perpendicular line when centered at closed clamps.
black = off axis hub and perpendicular dish reference result at wider hub.
red = off axis hub and perpendicular dish reference result at narrower hub.
Biggest "error" would therefore be a 29er front wheel
life-lines
Posted : 16/08/2021 9:12 pm
I have one of those, not sure whether it was from CRC or Planet-X but it was more like £70 back when I bought it. Nice and solid but I don’t bother trying to set it for dish I use a separate tool for that.
Posted : 16/08/2021 10:48 pm
I just built one out of my old kitchen table for about £20 quid, adapted from Roger Mussons design.
Posted : 16/08/2021 11:18 pm
