This is the pump I've been looking for
But seems not in stock anywhere
https://www.sigmasports.com/item/Lezyne/Pocket-Drive-HV-Mini-Pump/Q8WR
Has anyone got one ?
Blimey, how many similar versions of that pump are there?!😐
Is that not the one that’s just out? Probably just not actually available yet (if so)
Tweeks have it in Grey - https://www.tweekscycles.com/uk/lezyne-pocket-drive-hv-pump-2012573/
Cheers !!
Kimbers - when you get it would you mind measuring the exact diameter of the pump for me?
I have been storing the narrower version of this pump in my steerer tube (see thread here), and I'm wondering if this new HV version would also fit... Thanks!
Kimbers – when you get it would you mind measuring the exact diameter of the pump for me?
I have been storing the narrower version of this pump in my steerer tube (see thread here), and I’m wondering if this new HV version would also fit… Thanks!
@packer I was wondering this too after seeing your thread and this one. I've measured the image of the pump from the Lezyn website and I make it 27mm wide (if it is exactly 140mm long) so it won't fit in a 24mm ID steerer.
It'll be perfect for the new Boost standard headtube that will be along in the next year or so then 😉
Yeah, pretty sure it will be too big then unfortunately.
It’ll be perfect for the new Boost standard headtube that will be along in the next year or so then
It's only a matter of time! 😀
It's actually about 150mm long, including the rubber grommets and 32mm wide
Got it from Merlin in the end
It comes with a very secure looking bottle cage mount, if u want it on the bike
It fits perfectly in my camelback podium hip belt, which is what I wanted it as my other lezyne one didn't and I got my first puncture in years last week!
I’d advise checking the hose screws onto a presta valve ok before sticking one of these in the pack til you need it on the trail.
I have an Alloy Drive which I actually bought cos Lezyne pumps have always been excellent for me.., then, last night go to use this out on a ride and the frustration of trying to get the hose screwed on nearly tipped me over the edge of insanity. Only when I tested it on another valve and the hose from my road pump on the valve we couldnt get it to work on did I realise the hose is faulty.
Thanks to the passing riders who helped out by lending their pump!
