Lever for dropper p...
Lever for dropper post on drop bars?
12 Users
Bit of a niche I guess(?). Can anyone recommend me a dropper post lever for my latest drop bar ‘adventure bike’ build? I seem to remember demoing a gravel bike (couple of years ago!) that had a ‘double ended trigger’ type lever that could be operated by a finger or thumb from the brake hood - couldn’t see a brand on the lever though. It was a nice simple lever design and had a nice light action.
FWIW, I’m reusing my old BikeYoke Revive V1 post, so preferably need a lever where the end stop of the cable will sit - although I can fudge it to work with a plain cable, so lever with grub screw should also be ok.
TIA
Posted : 05/08/2024 1:11 pm
Your description sounds like my Fox Transfer one. Works well, nice light action, (although I suspect that's more to do with the seatpost).
https://www.bikeparts.co.uk/products/fox-transfer-drop-bar-dual-pull-seatpost-lever?
Posted : 05/08/2024 1:18 pm
Giant do one too, you can see a picture of it in this link :
http://cyclingmagazine.ca/sections/gear-reviews/new-2023-giant-revolt-x-advanced-pro-gravel-bike/
I didn't like the reviews of the Giant gravel dropper much, so specced my Revolt X with an AXS Reverb, actuated by pressing both STI levers at same time.
Posted : 05/08/2024 1:25 pm
I use one of these on my gravel bike, works well from both drops and hood though makes wrapping them bars slightly more of a fiddle.
https://pnwcomponents.co.uk/collections/levers-1/products/drop-bar-lever-kit?variant=49004474925349
Posted : 05/08/2024 1:54 pm
As above, I'm using  the Fox AXS Transfer lever on two bikes. I think it's ace. Worth experimenting with position before taping 'bars. I set mine about a finger's width below the hoods. Grubscrew at lever, as they should be, so you'll need to anchor the cable at the other end.
Posted : 05/08/2024 2:09 pm
The best solution if you're running 1x is also the most spendy one - a LH brake lever with the built in dropper lever - there's a Shimano GRX one, and I think also a SRAM version.
https://bike.shimano.com/en-EU/product/component/grx-11-speed/ST-RX810-LA.html
I've tried a couple of demo bikes that had the clamp on remotes and they were never near as convenient to use from all bar positions, or as comfortable.
Posted : 05/08/2024 2:25 pm
The best solution if you’re running 1x is also the most spendy one – a LH brake lever with the built in dropper lever – there’s a Shimano GRX one, and I think also a SRAM AXS Reverb version.
FTFY 🙂
Posted : 05/08/2024 2:29 pm
PRO (Shimano) do a good one. But as said the integrated lever version s are day and night better for activating without even thinking about it from the hoods or drops.
Posted : 05/08/2024 2:48 pm
I had good results from the crank brothers drop bar lever - just be really careful with the cable route, as with any similar lever. Any tight runs will make the lever stiff to use.
Posted : 05/08/2024 2:55 pm
Ah, thanks guys. I’ve got some of the new SRAM Apex 1x12 levers (mechanical shifting), so will investigate the left brake lever option before going with a separate lever.
Posted : 05/08/2024 3:44 pm
I have the PNW one linked above, with a PNW post.
It's alright but not particularly great.
I'd prefer a brake lever one or under-saddle lever would be ideal - so I could swap between dropper & normal post quickly.
Posted : 05/08/2024 3:48 pm
Some one on heat recommended the Fox one
It took some fiddling to get in the correct place. It’s fab. Not missing is being on the left lever
But spendy for a small piece of metal
Posted : 05/08/2024 10:24 pm
 jfab
You can take the ratchet out of a SRAM Apex shifter and it works well, although only if your left lever is actually a shifter lever and not one of their 1x specific ones that doesn't have the secondary paddle or any of the internal gubbins like mine is.
Here's the guide we followed:
https://www.bikeblogordie.com/2018/10/turn-sram-shifter-into-dropper-post.html
Posted : 07/08/2024 1:17 pm
