Lengthening a chain...
[Closed] Lengthening a chain?
8 Users
Is it okay to do this?
It's a SRAM 9sp chain, so is it safe to use 2 power links please?
Thanks
Posted : 11/06/2014 6:19 pm
I do on my tandem and haven't noticed any problems (it's 10spd)
Posted : 11/06/2014 6:30 pm
As long as you use a power link you'll be fine.
Assuming the chain is fairly new that is, otherwise the difference in wear will likely cause you some issues.
Posted : 11/06/2014 6:43 pm
Relatively new chain. Thank you chaps 😀
I now have a suspicion that I've only got some 10sp powerlinks 😳
Posted : 11/06/2014 6:52 pm
Is there a problem re-joining a chain using the standard pins if done carefully?
Posted : 12/06/2014 10:08 pm
Nope. I bought a nearly new chain off here and it was too short. Some very kind people sent me some additional links and I used the standard pins to join. No issues at all.
Posted : 13/06/2014 5:56 am
Don't push the original pin all the way out and you can use that. PowerLinks are weaker than normal pins IME.
Posted : 13/06/2014 6:58 am
I have two powerlinks on both my chains, no probs.
Posted : 13/06/2014 8:32 am
Cool, thanks for the replies chaps 😀
I have tried to join the chain using one of the original pins, but had problems aligning it, so figured that an additional powerlink would make my task easier and achievable 🙂
I've yet to break a powerlink, or chain for that matter so I must clearly put more effort in! 😉
Posted : 13/06/2014 6:45 pm
Don't do this. The riveting on the end of the pin has already broken off.
I'd leave a normal link inbetween the powerlinks.. Dunno why, but if I've done that then that's what I've done. 🙂
Posted : 13/06/2014 6:52 pm
