Trying to find out the length of the 100mm reverb. (from the seat rail to the collar at the bottom).
I assume it is 25mm less than the 125mm version, which is 196mm.
Can anyone confirm the length at 171mm?
Thanks!
I looked into this and got 165 and 171 numerous times.
As long as it wasn't more than that I will be fine.
Issue with having short legs!
Yeah I can just get away with the 100mm drop version. Not on an interrupted seat tube frame though.
Just been out and measured mine, I had a similar conundrum as I've got little legs too. The post is inserted as far as it'll go and from the centre of the saddle rail to the top of the seatpost clamp was 167mm or thereabouts.
Cheers guys. Just ordered one.
