Trying to find replacement bolt as mine has stripped but no joy. Anyone know where to get one or a workaround?
No luck on goggle or usual online stores as too old. Bolt holds crank on not just for bearing preload like hollow tech so needs to be strong enough
Part no in UK is 1H5 9804 but they’re discontinued, and SJS Cycles are all out of them, which doesn’t bode well for getting hold of one.
Full part no is Y1H598040 - you might find an international vendor with stock using that code.
Might be wrong but think an octolink bolt should fit and work as same thread and a close enough bolt size. Best way to check would be to go to your lbs as most have some lying around in a spares box!
I dont know if it does fit or not but i will check for you tomorrow as I have both cranks - give me a nudge { PM me] if i forget to check - it will be fairy late on when i get the time
Great thanks guys. Interested to know on the octolink bolt thanks Junkyard
Hmm, might have to see about making some... 💡
I’ve got one. But you’ll have to buy my cranks to get it...
Email me, I might actually have a bolt.
