LBS cost help
[Closed] LBS cost help
7 Users
Can anyone give me a rough idea of how much I should expect to pay at a LBS to change my existing SRAM X7 thumb shifter for an X0 gripshifter (Labour only as I've already got parts). Only on the left hand/front derailleur.
Thanks..
Posted : 03/03/2010 7:44 pm
However much they charge for a cable change plus a little bit more.
Posted : 03/03/2010 7:47 pm
Both front and rear shifters you mean I guess?
If so then I would say between £20 and £35, probably higher rather than lower as the shop won't be making any money on the parts, you may need new cables as well.
Posted : 03/03/2010 7:49 pm
If you came into my shop I'd charge you £6 plus the cost of whatever grip you wanted.
Posted : 03/03/2010 7:50 pm
Unless it's an edit, have you read the OP!?
I'd say £10 would be fair.
Posted : 03/03/2010 7:55 pm
Few glasses of wine and I'm anyone's.......
Ah then let me revise to £10 seems good.
Albino, just for my sake of mind, did you edit or did I misread?
Posted : 03/03/2010 7:58 pm
 br
Whatever their base level of labour is - 1/2 hour?
I mean, it must require a skilled, experienced person - otherwise you'd have done it yourself...
If you'd taken your car into a garage, somewhere between £25 and £50 for the same 'operation'.
Posted : 03/03/2010 8:02 pm
 jedi
my lbs doesnt charge for fitting if you buy it there
Posted : 03/03/2010 8:05 pm
Hi - Nope. I only edited original to change m mistake from X9 to X7 existing shifter.
It's only left shifter that needs changing as I've got some problems with my left thumb which means I can't use regular shifters.
Seems quite a range of prices so far. I'm happy to pay what the going rate is, even a little more as they wouldn't be making anything off parts. Just don't want to get stung.
Posted : 03/03/2010 8:10 pm
