Can anyone clarify how you put on of these newfangled seatposts with the cable coming out the bottom of the shaft?
Would the cable come out a bottle boss?
My head hurts. Trying to figure this out.
Do you have a stealth compatible frame?
If not you may need a drill
Indeed...no is the answer, I have a Krampus
I don't think you can get any stealth post in that size.
You will either need to exchange for one that is not stealth or pick a spot to drill a hole (bottle boss may work) SC do them at the base of the seat tube before the BB then route up the frame from there.
The euro bike pics show a KS Lev 27.2 stealth. Happier if I don't have to make holes in my shiny paint.
From what your saying you have a stealth? Or do you mean the eurobike pics show one with a cable that doesn't exit inside the frame. Where did you get the post from?
Sorry, I missed that.
If you go through a boss, I can't imagine the routing would be very nice.
Ideally, for the cable run, you will need to cut a slot not just drill a hole, and you need to be concerned about weakening the frame, not just the paintwork.
Have a look here:
[url= http://www.peterverdone.com/?p=4204 ]PVD[/url]
Mikewsmith...stw showed such future products from euro bike dream land
ah so you don't actually have one in your hand?
Given the static attachment on the standard lev I can't see any advantage in trying to bodge a frame without the right holes to fit an internally cabled one?
