KS Lev in line barr...
[Closed] KS Lev in line barrel adjuster install or not ?
11 Users
On a KS Lev installation are people fitting the in line barrel adjuster ?
Google suggests some are some not ?
Thanks
Posted : 13/02/2013 12:27 pm
 mmel
Not
Never had a problem with cable stretch and if you set the remote up carefully you shouldn't ever have a problem.
Even if you do it's an easy job to take the cable out and move the end clasp a little.
Posted : 13/02/2013 12:37 pm
Didn't do it here and all seems well so far.. *touches wood*.
Posted : 13/02/2013 12:40 pm
Many thanks
Posted : 13/02/2013 1:14 pm
I installed it on mine but not had to use it, can't say it was much extra hassle though
Posted : 13/02/2013 1:17 pm
I installed mine...why wouldn't you want to? In fairness, I've not needed to use it...but at least it's there if required.
Posted : 13/02/2013 2:50 pm
I did and I've used it, possible due to mechanical incompetence with the intial isntall, but this is the equivalent to bleeding a reverb when it stops working. The LEV is ace in that respect, the only issues I've had with it were fixed by a twiddle one way or the other with the adjuster.
Posted : 13/02/2013 2:54 pm
Not fitted and not needed yet.
Posted : 13/02/2013 4:03 pm
Fitted mine on both bikes and used it very very occasionally.
Posted : 13/02/2013 4:10 pm
 burt
fitted mine but will remove it when i replace the cable next time, looks ugly and not needed it
Posted : 13/02/2013 4:16 pm
I didnt on mine
Posted : 13/02/2013 8:16 pm
I did on mine. Just allows me to take up the slack so you get an instant response on the lever.
Posted : 13/02/2013 8:47 pm
I also put a flexible section coming out of the lever to stop the housing bulging out to the front of the bike.
Posted : 13/02/2013 8:54 pm
