KS Dropper - cable ...
KS Dropper - cable cylinder disconnecting from coupler
5 Users
2 Reactions
Not sure if I'm missing something here but after replacing the inner cable, the cable-holding cylinder at the internally routed post end keeps disconnecting from what the exploded diagram calls the coupler.
The cylinder is still crimped onto the cable fine when I pull the post out - most of the internet help on this is for this problem. The coupler only has one side with a hole for the cylinder and a small bar to support the other side of the perpendicular cylinder which seems like it would stop "holding" that side and allow it to come away when the cable is pulling the coupler down.
Any tips on how to secure it?
Posted : 29/07/2024 10:12 am
The cable outer should fit snugly in the base of the post once the inner has been hooked on. This should stop the cable moving enough to detach the inner as you put the post back into the frame.
Do you have the other end of the cable still attached to the trigger? If so, that should stop it moving enough to detach.
Posted : 29/07/2024 11:19 am
As above,  sounds like you are not keeping the cable tight when you are putting the seatpost back in.
Posted : 29/07/2024 11:26 am
weeksy and weeksy reacted
Looking at it via a zoomed in photo and I think that the tip of the coupler has broken off. Trying to source a replacement.
Posted : 29/07/2024 11:31 am
Coupler should look like this:
(Picture from here )
Posted : 29/07/2024 11:44 am
yeh mine's definitely well short of being a semi-circle - thanks v much for posting that pic to confirm
Posted : 29/07/2024 12:20 pm
SLAM69 seem to stock a lot of KS parts. Can't see the coupler, but they have a note to give them a ring if you want something that's not listed.
https://slam69.co.uk/collections/ks-dropper-post-spares
This might be an upgraded replacement (guessing!)
https://slam69.co.uk/products/ks-lev-coupler-dropper-post-spares-p5728
Posted : 29/07/2024 1:15 pm
pedlad
I had the exact same problem with my KS dropper. New coupler fixed it. IIRC, it was a warranty job for me
Posted : 29/07/2024 5:46 pm
I switched over to a lever that secured the cable thread end and got the fitment barrel for that, saves a hell of a lot of pain, as when it comes loose, you just can't fix it trailside.
Posted : 29/07/2024 5:55 pm
