Hi - I have a Kona Kula Gold from 2011, I need to replace the headset bearings. Anyone know what size I need? I've tried the Kona website and it just says TH. Can't find the info anywhere.
Mnay thanks
Hi,
Could try the Kona Tech Forum somebody may have asked the question before or you could ask for yourself. I have found the Techs on there very helpful.
[url= http://forums.konaworld.com/index.php?showforum=12 ]Kona Tech Forum[/url]
Cheers, trying that at the moment. Annoying that Kona don't state the spec on the Konaworld website.
[suck-egg]Have you removed the bearings?[/suck-egg] They might have a code similar to 7H x 41.8 x 30.2 x45deg x45deg, which is the sizes in mm and bevelled edge angles
