I have an old kona cindercone 97 18"
The bike has been converted to single speed with the use of a chain tensioner. The steel frame is damaged in several places with the usual cable rubs and chain damage on the stays. I think the frame needs a respray.
The wheels, brakes and other kit are not that special and probably could be upgraded but is all of this worth it?
I really enjoy riding the bike (as it it stands now) but I could buy a dialled prince albert or a cotic simple for instance for less than £1k?
I will post varous pictures and a detailed spec shortly.
I would really value the forum's collective opinion on this one 🙂
Thanks in advance...
It ay be a bit mmodern but you'll get a lot of help if you ask on
[url= http://www.retrobike.co.uk/ ][b]retrobike.co.uk/[/b][/url]
A fountain of knowledge awaits you there,
unless you have a burning need for disc brakes or suspension, just ride the thing and replace stuff as it wears out - spunking £1k on a very similar bike is just going to leave you wondering if it was worth it
'needs' a respray? doubt it - 'looks a bit tatty' maybe, same as any bike will after a while
looks fine to me, apart from that 'shopper' stem.
what they said - Inc the stem
You could cost up discs and sliding dropouts, if you really like the bike and will keep riding it.
It looks like a fun bike!
If you wanted to upgrade the braking you could get a disc fork (and wheel, and brake etc)
And I wouldn't worry about respraying it etc. It'll never be a museum piece, so just ride it!
if you want a respray, get a respray.
any idea of price etc?
any other ideas on upgrades for this bike...the wheels are a mismatch of Mavic 221s on the rear with a shimano deore hub and Mavic 238s on the front with an unnamed hub.
Forks are P2s
Tyres I have just replaced with Kenda Blue grooves
Cranks are Raceface ride XC
Saddle is a Flyte
bars are Raceface flat
brakes are avid Vs
just ride it, don't get it resprayed, it works for you and must have done for a long time maybe get ceramic rims and poncier v's next time you wear your rims out
fix it up but too a budget, get second hand bits of classifieds and touch the paint up with a car touch up pen. just take it into halfords and match up. looks a little old but so what, will look much better after a bit of tlc. ENJOY
I'd recommend superstar v brake pads - i love them. just put new cables etc on it and she'll be running sweet in no time.
Worth keeping it going, yes
Worth a respray possibly
wortk real work like disc mounts and sliding dop outs? IMHO the cost of the work is to close to a new frame. Unless you want to keep it going
Yes I have had it since 1999...we have done the south downs together three times to name but a few rides...
I have some of those stickers for rub points etc so I could use those to patch up the paint work.
The stem looks weird but works. I will try to put back the original which was less extreme 🙂
Thanks Bez - not bad price 🙂
I would like to keep the original colour but I probably got no chance matching it 🙁
colour match no probs.
If you are rrspraying and getting new wheels you'd be silly IMO not to get disc mounts abs sliding dropouts
I've got one of those still going, and it's in a much worse state... had 2 visits to the welders and is partly primed, partly painted. Still running well with drop bars, slicks and mudguards as a poor weather commuter.
I'd not worry about the respray, get some touch up paint for it (Car places will do there best to colour match).
With a small amount of filing to the dropouts, you can run 32-16 without a tensioner on the 19" version of the '97 frame so I assume that the same trick will work for an 18" version.
Not worth restoring. Let it die in style - ride it into a tree.
I will ignore that last comment Shame-He-Likes-Bikes!
How do you do that then Paule?
Er. You get a file and you file the dropouts. Effectively shortening the stays.
Be sure it'll work before you do it, though. Magic ratios vary on Konas (I have had 34:17 work on three of mine - one perfectly, two with filing - and 32:16 has never been even close to working).
AW, you have too much time and money. Why don't you spend both on [b]sex and drugs, and rock'n'roll[/b]? The bike looks fine, ride it or not it won't be worse than a £1k modern thing (and that's a lot of drink in my books).
[i]Or just send it to me, I'll pay for the courier.[/i]
