Knocking/rattle on ...
Knocking/rattle on SID select..anything to worry about?
6 Users
 DrP
I'm certain my MY22ish SID selects have slightly loose bushing.. certainly feels like it doing the rock test.
Anything to worry about? I know this model year did have reported issues.. trouble is the bike came from BikeInn, so warranty may be a pickle (but not impossible)..
should i persue this?
DrP
Posted : 07/05/2024 8:13 am
If the rock test requires the front brake to be held on are you sure it's not the pads moving in the caliper.
Posted : 07/05/2024 8:22 am
 DrP
yeah...reattels for and aft, and with wheel turned 90 degrees..
DrP
Posted : 07/05/2024 8:33 am
Warranty should be fine. Go to your nearest SRAM dealer and bribe them (£10-20 should do it) to warranty it for you. You will need a copy of the receipt.
Posted : 07/05/2024 9:08 am
I’d say have a go at warranty too.
im on same bike and fork and year AFAIK with no hint of a similar issue - just to rule out any sense of “they’re all like that”.
you could even try a local specialized dealer.
Posted : 07/05/2024 9:16 am
I had the same thing with a set of SID Ultimate forks.
I took them to a local shop and the guys there returned them to SRAM who replaced the lowers.
Posted : 07/05/2024 9:33 am
 DrP
cheers all - will try that route...
DrP
Posted : 07/05/2024 10:05 am
They are just like that. Mine started doing it after a couple of moths. Rideable but not ideal. Got new lowers for them after 2 years, fitted last November, was perfect for a while but just noticed it happening again on last night's ride.
The latest versions have completely redesigned lowers / bushing overlap, so it's a known issue.
Posted : 07/05/2024 10:39 am
