https://www.amazon.co.uk/dp/B00I8N282O/ref=cm_sw_r_cp_apa_fab_ui7yFbE68MNBA
Vs
Traditional mole grips in the workshop?
Which did you and why?
Hex keys or hex heads on a ratchet - which is best for you and why?
Hi!
I have both the Knipex and a couple of different mole grips. The long nosed ones are the ones that work best for me in small spaces.
On the hex keys I only tend to use the Wera hex plus. They don't cost an arm and a leg and have never failed. I have a set in the tool bag which doubles up with everything for races. A set in the camper and one of the shorter sets in the van, bought our daughter a set for Christmas and they should last her a lifetime. I also have a 6mm and 8mm in the pedals box for ease of finding. The 8mm has the rubber cut down so it will go through the crank hole.
There are quite a lot of tools that aren't a necessity but make the job easier and quicker.
I can't think of a single time I've ever used moleys when it's not a last resort. The Knipex should be the same.
My buddy refers to them as the idiot spanner.
Park folding hex and Torx sets are my go to.
As I always say. Multifit spanner /those knipex have no place in a workshop.
They are good in a pack / pocket where a range of correct spanners would be weighty and take up alot of space.
Adjustable spanners pli-spanners and molgrips are last resort in a workshop situation.
So the correct spanner would be my choice
Molgrips /pli spanners are fairly different tools as well. Ply spanners are pretty pants on round things.
I've got hex keys and bits. The bits fit in the torque wrench and mini ratchet and 4,5,6 and (T25) are all Wera.
Mole grips I've got some needle nosed and then 2 big ones and 2 smaller ones. Large ones hold a brake hose block easily to tap in the barb (or can even grip a shaft clamp).
Also quite useful for random clamping, cables etc when you don't want to pull it out.
I can’t think of a single time I’ve ever used moleys when it’s not a last resort.
I have a set of mole grips for exactly those times. Was looking at at a set of Knipex the other day, for more options in those situations.
Hex and Torx wrenches - another vote for Wera. I also love ratchet spanners too and the Halfords Professional ones have worked well for me - as have their sockets.
Different tools for different jobs.
The Knipex are a better adjustable spanner. There’s a time and a place for them, but not as often as you think. Molgrips are the “it’s already *ed, doesn’t matter if I * it some more” option.
L-Allen keys, T shaped ones, socket bits all have a use. I’ve a miniature Wera ratchet that takes 1/4” hex bits that’s great for getting awkwardly located bottle boss or saddle clamp bolts done up quickly. You’ll probably need a set of 1/4” square bits if you plan to use a torque wrench much.
Yeah sorry, totally agree. My meaning was that I don't think they should be an 'alternative' to Knipex jobbies.
The moleys to me are a 'keep at home in a the emergency drawer with the Irwin bolt extractors' tool, and the Knipex are, as above, a 'take a set when I can't fit all the right size spanners in'
I know people seem to love the Knipex on here, but I have to be honest, I'm struggling to think of what they could be used for on any vaguely modern bike - pretty much all cap heads, and if they round off, then it's time for moleys/gator grips.
Now what I really need is a set of nice T handles that aren't daft money.
Because usually a folding Allen set is not the right tool!
Rarely use my molgrips
Knipex plier wrench rarely used on the bike, really handy for general stuff. Have a medium size one and the baby one too. Best use on a bike is straightening a dodgy disc
The molegrips Vs knipex q is when proper tools are exhausted, to grip stumps of bolt etc
Molgrips then.
Molgrips and Knipex = tools for cack handed spanner monkeys.
I've seen a pair of pliers used instead of a spanner once, in 28 years of Engineering.
The guy was thicker than a whale omelette.
A 150mm knipex has earned its place in my front pocket of my work apron.
Used for all sorts of jobs on the cheap or older bikes our shop works on.
I'm thinking those who are knocking them maybe don't have a set? They really don't slip or damage anything if used correctly. They've never let me down and are always at hand.
I've got a drawer of spanners which see just as much use though.
I'm moving to a shop where I'll mainly be working on newer stuff and I think the knipex will be gathering dust there. Never use them on my bikes.
Never used molegrips on a bike
Hex keys all day long but the little rachet comes in handy for hard to access stuff.
The knipex pliary things are ace, but I don't find they do quite the same job as moleys, I have both and use both.
For a bike, and for some reason for a 3d printer and for remote control cars, hex keys. For bigger stuff, again, both. Not a better or worse thing but I think if I had to, I'd have just the keys.
I learnt the other day about Molgrips. He's not a tool 😉
Molgrips are good for holding things that you don't want to hold in your fingers, like they are being heated or cut or something. They are rubbish at holding things you want to turn like rounded bolts etc, I don't think I've ever successfully done this except when I'm able to hammer the offending bolt to say 45 degrees - then they work. A set of stud extractors or similar is a great investment otherwise though.
molgrips
Free MemberMolgrips are good for holding things that you don’t want to hold in your fingers, like they are being heated or cut or something. They are rubbish at holding things you want to turn like rounded bolts etc, I don’t think I’ve ever successfully done this except when I’m able to hammer the offending bolt to say 45 degrees –
I think maybe you need better molgrips (yes yes, it is very amusing). And also to turn them up a bit! For best results you want to barely be able to close the grips.
They're not a one-tool-fixes-all thing but then, nothing is, with stuck bolts. But they're a useful part of the "throw the kitchen sink at it" kit.
Ha! I will be stealing that
I can see that they are not a replacement for a set of spanners, but I have a pair of the knipex grips in my general household toolkit - they get used all the time for little random jobs, along with my Wera "toolcheck" kit
This. You need a variety of tools for different purposes.
T-handle hex keys are very versatile for most bike work. Plus, of course, a mini-tool in your backpack. A set of standard hex keys is useful to have, they often fit in tight places the T-handle ones don't. Plus, hex heads, a powerbar, extension drive with u-joint, and torque wrench are pretty handy of you do a lot of work on bikes. So that makes two to four different hex tools for different purposes. Same goes with spanners, pliers, etc. You need a variety.
Has anyone tried the park sliding t handle hex keys? They look rather nice but are a bit spendy
I find molgrips great for plumbing, they're ideal for holding inline valve bodies whilst you use a spanner to crank up the nut on the end.
They're also handy for removing tubeless tyres...
[url= https://live.staticflickr.com/65535/50344727672_6996c9b950.jp g" target="_blank">https://live.staticflickr.com/65535/50344727672_6996c9b950.jp g"/> [/img][/url][url= https://flic.kr/p/2jGMTy5 ]Mother of god tight tyres[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
I find molgrips great for plumbing, they’re ideal for holding inline valve bodies whilst you use a spanner to crank up the nut on the end.
I have used an adjustable spanner to do exactly that!
For me, I have never needed to use molegrips on a bike, although I do agree with a poster above, Knipex used properly are not destructive.
https://i.postimg.cc/nrkVr2fW/IMG-0300.jp g" target="_blank">https://i.postimg.cc/nrkVr2fW/IMG-0300.jp g"/> [/img][/url]">
+1 for Batfink's Wera toolcheck, + more Wera loveliness
Can't post pics 🙁
Can post pics:)
Molegrips can be clamped on (and if there is room you can clamp 2 on for example a shaft)... even if you use a knee or something to stop them moving it frees up a hand.
Knipex pliers and molegrips aren't really comparable.
There are plenty of little jobs the Knipex pliers are great for. They don't slip or mark like cheap adjustable spanners, you need to pretty hamfisted to damage something with them.
I've used them for holding bladed spokes and undoing bleed nipples anything where you don't need masses of torque and the smooth jaws won't mark the work. Handy round the house too.
If you are loosening stuff with molegrips then its probably already trashed anyway. The only bike job I've ever used them for is clamping the yellow blocks you get with Shimano brakes when you are tapping in a barb. Ideally you would use a vice but that's not really practical if the hose has been threaded through the frame.
Ive been fancying some of those knippex pliers for a while. but they are just that, pliers. they will mark a surface that a spanner wont so why would you use them?
as for t handles. Again im unsure of why? they restrict movement. look nice though.
Fair point, I haven't had a nice expensive pair. But the issue with bolts and studs is usually gouging of the metal which causes it to slip. I'm sceptical that anything that could be turned by molgrips cannot be turned better by something else.
For suspension forks and the like, I make shaft grips out of blocks of hard wood by drilling a hole then sawing through the hole. Works quite well.
Speed.
As someone said above, they're good enough that you'd have to be pretty incompetent to damage or mark anything if using them properly. Also as above, they're really handy to have for general stuff but don't think I've ever used them on a bike.
Yep I do that but I've still stuck a stubborn airshaft in the vice and then added another wooden block to use molegrips as well.
You need all of the above tools.
You might not need them often but when you need them, you need them.
See, to me knipex make some nice Side cutters and other assorted tools. Without the pic in the post I'd genuinely have no clue what was being referred to.
For undoing stuff in a satisfyingly barbaric way my 24" Facom pipe wrench (or stilsons) works well.
This thread has reminded me not to forget to order this year's Wera advent calendar though
So wera hex keys ftw?
andybrad
The Knippex pliers are the least likely to mar the surface of your nuts. I've not damaged a nut or bolt head yet.
I carry a set on my old British bikes instead of carrying half a ton of fixed spanners for every contingency.
or stilsons
I wasn’t going to mention my favourites, various sizes of stilsons and some water pump pliers😀 Neither used on a bicycle.......yet
Where you can get a spanner on it, do that.Its the best way. Stilsons are handy for stubborn things that are probably going in the bin when they eventually come off. They can really chew up a nut / fitting/ pin, etc. Usually only any good on soft things, hardened things will bugger up the teeth.
I use my old, British made molegrips (actually made by Mole) all the time, my favourite tool for grabbing awkward ,snapped, hot, sharp , or irregularly shaped things. The jaws on mine form a triangle so they force the gripped object towards the jaw rivets, where the grip is strongest. The grip is awesome.
Bondhus allen keys are great, but the best ones I ever had were some super Gucci Wiha ones that were ordered in error in work. They were shockingly expensive but they are the bollocks, cant take your eyes off them in the workshop, everyone wants them.
https://www.wihatools.com/hex-tools/magicringr-ball-end-hex-l-key-metric-9pc-set
These shiny bad boys. The strength is very surprising.
andybrad
Full Memberas for t handles. Again im unsure of why? they restrict movement. look nice though.
Lots of reach, you can get them into places that you can't other tools. And they're very fast in use- doing say 6 bike brake disc bolts with a T-handled T25 is so quick.
bikerevivesheffield
Full MemberSo wera hex keys ftw?
I think I'm the odd one out, I don't really like my Weras. The hex-plus works great when it works but on smaller and lower quality bolts especially I'd rather just have a good quality hexagonal end. (Wera do make these too, but they're harder to find, and a bit pricey imo)
I have a really nice set of Inbus keys, I love 'em but I can't argue they're a good buy, too expensive. They're no better in use than the much cheaper Teng ones I use day to day
For workshop use I would 100% get a good set of P- or T- handled Allen keys. I’ve got Bondhus T-handled ones which are still great after a decade of use. They’re much easier to grab and more ergonomic to use.
You’ll also want some decent L- shaped ones for those hard-to-reach bolts.
I’ve never really used the Knippex-style pipe wrench things on a bike. I’d be worried if a bike workshop had those tools handy tbh.
Your concern about seeing the plier wrench in a bike shop makes me wonder if you've used one at all?
Those Knipex pliers are brilliant, you can't compare them to molegrips which are just for holding stuff really tight and normally cause damage. I use them all the time at work (aviation) and they definitely don't damage the nut if used correctly. The only time I've used mine on the bike is fork top cap removal as I don't have a suitable socket for mine.
Just make sure you get the metric ones if you're using them on your bike...
Your concern about seeing the plier wrench in a bike shop makes me wonder if you’ve used one at all?
It’d be weird for me to comment if I hadn’t?
IMO they’re in the same category as hammers and easy-outs. Useful to have around but ideally to be avoided when bike spannering. Keep them under the workbench and leave them there unless you really need them.
I personally wouldn’t use them on my forks (^^^) although you do you. But I’d be upset if a bike shop used them in lieu of the proper tools.
I've probably had the top cap off about 5 times and there isn't a mark on it, obviously if I had the appropriate ground down socket I'd use that, but I don't...
Mine get used a lot for various things. The big ones (300mm) are great for leverage, and the jaws lock in place with minimal pressure on the grips.
The benefit of the parallel push and the leverage means you can bend stuff with them too. A flat tool sitting parallel with a rim can be used to steady one side of the jaw while you use the other to push a dent straight. Much safer than the mole grip method of gripping and bending.
The 125mm set are great to carry instead of Leatherman pliers, and I’m also looking at a 100mm set of Knipex Cobra water pump pliers for the most annoying little jobs.
They won’t marr happybiker because they are parallel push
Most people on here slagging them off have no idea what the actually do .
Look in any pro mechanics box at races you’ll see a set of those
I imagine people poo-pooing the Knipex plier-wrench often haven't used them.
I've got a set of nice open and closed end wratchet spanners, but the Knipex is great for jobs where you can't get a spanner in as easily.
Also for truing rotors, imperial/odd sized nuts, etc.
The fact they adjust outwards in fixed steps, and then move parallel to grip means you don't get the slippage you would with a normal adjustable.
Not a replacement for a good set of spanners, but definitely a complimentary tool to have.
Along with some Lidl tools?
They work well for the amount of times I use them.
The hex, torq and Knipex get a lot of use. I’d be pissing money away if I bought Abby Tools chain tool, bottom bracket tool and the like. Put the money where it is justified.
