knackered fox float...
[Closed] knackered fox float 32s
4 Users
anyone ever taken the damping cartridge apart on older floats (2006 rlc 130mm)
rebound adjuster keeps on turning with no effect
failing that anyone got a spare cartridge kicking around?
cheers
Posted : 19/12/2012 11:51 pm
I have many times, there are vids on youtube etc that will point you in the right direction.
I also have a Terralogic Cartridge that will fit if your fork is origional Fox and not oem. Taken from my 07 TTL Float fork which I converted to RLC. I beleive their the same chasis. I had to srtip down the RLC cart and swap out the top cap assembly for a new one as the threads are different on oems to genuine Fox forks.
Posted : 20/12/2012 12:48 am
Sounds like you've snapped the tangs off the rebound metering rod. Just had this sorted by loco. Sent him the cartridge rather than the whole fork. Think it was about £35. I was happy to try and strip it myself but I just couldn't get the parts.
Posted : 20/12/2012 5:50 am
cheers for that guys
for 35 quid its worth going via loco!
Posted : 20/12/2012 8:36 am
 LoCo
As above, fixable, probably the tangs on the end of the meter rod maybe a barrel adjuster too, it's best to use the correct shaft clamps to strip it though as it's pretty easy to distort the damper tube as they're pretty thin. 😀
Posted : 20/12/2012 9:20 am
