Kids shotgun handle...
[Closed] Kids shotgun handle bars?
4 Users
Does anyone know if there are two options for the kids handle bars? Online says they will do upto 35mn bars, I've had a set for a year on 31.8,bars and trying to fit them to 35mm bars today and when fitted the bolt holes no longer line up
Sam
Posted : 06/07/2020 5:35 pm
Yeah they changed them a bit to fit 35mm I believe. TBH they aren’t the best in 35mm mode. For 25.4 you have a chunk of rubber shim, for 31.8 it’s a thinner rubber shim, for 35 it’s metal on metal (or even worse metal on carbon)
Posted : 06/07/2020 6:14 pm
I got some on Saturday, Mashr is correct. Although even with the thin spacers it it was a struggle to start the thread off on 31.8.
Posted : 06/07/2020 7:25 pm
I've filed pretty severe chamfers on the ends of the bolts to help them locate better. Works better now on 31.8 bars. Although the shims still slip as the adhesive is rubbish!
Posted : 06/07/2020 7:49 pm
Yup, I had to bend one of the clamps to allow the screw to locate. Not exactly a top quality product, luckily they’re fine once installed
Posted : 06/07/2020 7:54 pm
