Kids bike repair he...
[Closed] Kids bike repair help needed, ikkle cranks content!
4 Users
Hi All
I hope someone can help, I have not done much work on kids bikes before!
My son has a halfords "Hood" mountain bike, the thread on the drive side crank has worn, so the pedal will not attach securely.
I would like to re-comission the bike and am looking to see if anyone knows where parts for this type of bike can be purchased.
The cranks are approx 140mm long and have a aquare taper, with a 13mm bolt securing them. The chain ring is part of the same moulding as the crank.
(The bottom bracket feels rough as *****), so a solution with a bottom bracket would be good!
Thanks in advance for any help received.
Al.
Posted : 12/07/2012 9:52 am
I guys I realise this is not about Shredding the Gnarr, but thought someone would have been able to point me in the right direction?
Go on ............please!
Posted : 12/07/2012 3:43 pm
 GW
Remove the other crank arm and BB - it will be loose ball FAG style (you can cheat and just remove l/h cup) clean, re-grease an re-asemble. ( new bearings if req.) Source a new crankset of similar length and fit it to the (clean) axle to the correct torque. Done.
LH BB cup adjusts bearing preload, lockring holds it in place
Posted : 12/07/2012 3:54 pm
 trb
Alas these types of bikes are not generally made to be repairable, and indeed your average punter won't bother to repair it. ergo there is no demand and as a consequence no supply.
option 1 : Ditch it and buy a new bike like yer average punter.
option 2 : Scrounge around the tip / free ads / ebay for a similar bike and swap the parts over
option 3 : Go to an LBS where they recycle / sell a lot of second hand stuff and see if they have anything.
Good luck
Posted : 12/07/2012 3:58 pm
Thanks GW
Where is best to get new crank arms?
SJS Cycles (St John Street) in Somerset will be a good start.
PaulD
Posted : 12/07/2012 4:05 pm
 GW
Any lbs that sells cheap kids bikes like concept, emelle etc can get hold of a suitable crankset
Posted : 12/07/2012 4:12 pm
