Setup is KICKR Core, usually connected to ELMNT Roam although sometimes use Zwift on iPad instead. I also have an iPhone I use to configure stuff on the Roam. No other electronic devices in same room.
The only way I can semi-reliably get the Roam to see the KICKR is to make sure the iPad is nowhere near, and to turn Bluetooth off on the phone from settings - not from the pull-down Control Center. Even then I sometimes need 2-3 power cyclings of Roam and KICKR to get the Roam to see the KICKR.
Otherwise as far as I can tell one of the two Wahoo apps on the phone will always "grab" the KICKR connection, not leaving it available for the Roam.
The above process came from some back and forth with Wahoo support (who are really responsive, I should add), and all devices/apps up to date with patches etc. But - it all feels a bit of a faff, as I'm often messing about for 10 minutes before a workout to just get the devices to see each other.
So question is - anyone else experiencing similar problems?
The thing that always catches me & Mrs out is that you have t have Location switched on, even though you're static.
