Anyone use and keep their turbo trainers outside?
Just built a deck which isn't covered, keen to set the turbo up out there and leave it out at least until the proper wet weather gets here.
Assuming it probably wont like it too much - neither will the bike. Anyone already do this and have any recommendations for keeping it in good working order. Is a bike cover enough or has anyone got any better recommendations.
I'd prefer to leave it set up so i can just jump on it - not have to dismantle and put it back together each time.
The wife's one is outside ATM for much the same reasons, stuck a BBQ cover over it. If it was going to be long term I'd probably look at a motorcycle cover as they can be a bit larger and hence may give better water secure coverage. ours mainly gets used outside until its proper cold and wet.
