Keep the 140mm Floa...
[Closed] Keep the 140mm Floats or sell with frame and go 120mm?
8 Users
Hi guys,
I am in the process of swapping the kit from my 2010 Orange 5 over to a Cotic Soul as the job/new baby combo mean i can only justify one bike.
So the question is, do i keep the 140mm Fox Floats (recently Mojo'd) and run the Soul at the upper limit or sell a frame/fork/shock set to fund a 120mm set?
Or try the Floats and sell them seperately later if i fancy the change?
Anyone run a Soul at 140mm?
Chris
Posted : 10/12/2013 3:55 pm
Reduce them down to 120mm with the correct spacer http://www.mojostore.co.uk/acatalog/Travel-Spacers-2.html
instructions here http://www.cyclistno1.co.uk/features/maintenance/fox-forks-travel-adjust.htm
Andy
Posted : 10/12/2013 4:05 pm
I found my soda front end light with 130mm floats
I believe the geometry is the same as the soul
Now run 120mm - feels perfect
I'd spacer them down to 120mm- 32s are just about within their comfort zone at that length.
I had my Soul everywhere from 100mm to 140mm, it had a different character at every setting but did do some jobs better than others. 120mm was probably the best balanced setting but I reckon it was pretty much the bike u-turn was invented for, the 100-130mm u-turn Rev was just [i]perfect[/i]. Got my Soda set at 120mm now with Sids, and very happy with that.
Posted : 10/12/2013 4:19 pm
Correct me if I am wrong but doesn't adding a spacer to floats just stop the stanchions moving all the way down and not affect the height of the fork?
Posted : 10/12/2013 4:34 pm
No, it reduces the axle to crown by 20mm as well as the travel
Posted : 10/12/2013 4:36 pm
 zip
I'll be interested in the Floats if you do decide to sell.
Posted : 10/12/2013 4:45 pm
All,
Thanks for the comments, had not even considered using a spacer as I also thought that it only reduced usable travel - I'll give it a bash.
Zip - if i sell I'll give you first refusal.
Chris
Posted : 10/12/2013 9:34 pm
Ride it at 140mm first, you may like it - I do!
Posted : 10/12/2013 10:24 pm
