KCNC Bottom Bracket...
[Closed] KCNC Bottom Bracket Knackered - Can you replace bearings only?
3 Users
This is probably a utterly naieve question but can you change just the bearings in a KCNC press fit BB? Looks like the wet winter may have taken it's toll on the whippets BB as the bearings are seized.
Posted : 30/04/2014 7:56 pm
Did it last well? and which kcnc BB fits a whippet? cheers
Posted : 30/04/2014 8:00 pm
It lasted about 6 months but to be fair it has been well and truly submerged in water and mud all winter. Really easy to fit and remove and the info on the part is K-TYPE-BB 92 for 89.5x41 0r 92x41 frames part number EK08235
Posted : 30/04/2014 8:12 pm
Actually that's a lie probably more like 12 months.
Posted : 30/04/2014 8:13 pm
Nobody?
Posted : 30/04/2014 9:09 pm
Yea mate you can I did it last week on my lapierre spicy
Remove the top hats carefully u may need to buy some new ones as they are a bit brittle and can break
Then using a drift tap the bearings out from the inside I just tapped gently going around the bearing
I then tapped the bearings back in with a small mallet , no need for a press a bit of grease helps
I've had mine on the bike for about 2 years with no problems
Posted : 30/04/2014 9:33 pm
Excellent, thanks spicy. Do you know a good source for the bearings?
Posted : 30/04/2014 9:35 pm
cheers johnj
Posted : 30/04/2014 10:02 pm
Just did a search on 6805-2RS the bearing seal showed 56805-2RS for some reason I don't know what the 5 in the front means but it did have KCNC on it as well
They do vary in price just have a look on google for a bearing company I think I paid about £5 each but they did go up to £10/15 each
Pop a bearing out and double check the size or you maybe lucky and just have to remove the top hat to see the number
I used WYCH bearings
http://www.wychbearings.co.uk/61805-2rs_budget.html?gclid=CJm-l6Gdib4CFWTlwgodpL4AcQ
Or you could try simply bearings
http://simplybearings.co.uk/shop/advanced_search_result.php?sort=2a&search_in_description=0&keywords=6805-2rs&x=28&y=2
Hope that helps
Posted : 30/04/2014 10:15 pm
Ended up buying a complete Token BB from On One to try out, pretty much the same price as the bearings at 22 quid.
Posted : 30/04/2014 10:17 pm
The only issue I can see with the KCNC bb would be getting the Ali casing out of the frame bb shell
From memory there did not look like there was a lip on the in side to unable you to drift it out (on mine anyway)
It just appeared very smooth on in side I wasn't fussed as I was very happy with the product and would just change the bearings
Let me know how you get on with it
Posted : 30/04/2014 10:23 pm
