No spare inner tube so that's the morning ride wrecked. Well and truly pissed off !!!
where do you live ?
(and what sort of valve?)
Don't Halfords open early?*
*Assuming you have one near you.
Not even an old punctured tube you could cut the valve out of? (Or pinch the inner bit.)
Sorted now chaps ta. mate had a spare tube. Will any tubeless valve ie mavic Stan's etc work with easton haven wheel ?
Should do. Was it a Presta valve? Get a superstar one for half the price of Stan's
Snapped as in the top bit? Is the core removable? Spares can be had for cheap for next time.
Yes presta and yes snapped the top bit. Very weak if you ask me, only used it about 10 times. None removable so it's knackered
Don't sweat it. Calm down.
Both my bikes have home made valves. Just cut them from old tubes. Feed the sealant in from bottom of tyre. Pull valve tight with lock ring . Done.
