Just dug my Camelba...
[Closed] Just dug my Camelbak Bladder out of the garage - WWSTWD?
22 Users
Whilst hunting out my winter gloves I came across my Camelbak bladder which was probably last used in the era pre-Covid! It still had water in it... There was no obvious mould anywhere and it smelled that same as I remember when I was using it regularly. I've washed it out with effing hot water and Fairy Liquid but...
...would you use it?
Posted : 05/11/2021 5:55 pm
Milton it and then yes...
Posted : 05/11/2021 5:56 pm
Yes. I might soak it with a Milton tablet first
Or dilute plain bleach (hypochlorite stylee preferably) if you have it
Posted : 05/11/2021 5:58 pm
Swill it out , chuck it in the freezer and use when needed.
Posted : 05/11/2021 6:02 pm
Hot water. Washing up liquid. Give it a wash (in a plastic washing up bowl, in the kitchen sink, just to set the STW massif off 🤣). Give it a rinse. In the freezer. Use as required. Oh, don't forget to use the dishcloth that's left from the previous washing up too...
Posted : 05/11/2021 6:11 pm
Why the freezer? Most lurgies don’t get killed off, they just hibernate.
I'd certainly be giving it a good bubbly scrub, rinsing out then sterilise it with milton/starsan/bleach.
Posted : 05/11/2021 6:16 pm
I'd use it, maybe after the milton/bleach wash if I had any
Posted : 05/11/2021 6:26 pm
Yes, people are far too squeamish about this stuff. Mine has permanent black stuff in it, but it's fine.
Stock up on imodium 😁
Posted : 05/11/2021 7:04 pm
Beat it with a bit of 4x2 with a nail through the end until it stops moving
Posted : 05/11/2021 7:14 pm
Thanks @ernie, but I suspect your method may be somewhat sub-optimal when considering future fluid retention performance...
Posted : 05/11/2021 7:46 pm
I stored mine in the freezer and somehow it has become impregnated with the smell and taste of garlic - very refreshing
Posted : 05/11/2021 7:50 pm
Thanks @ernie, but I suspect your method may be somewhat sub-optimal when considering future fluid retention performance…
Shouldn't leak too bad if it's come straight out the freezer
Posted : 05/11/2021 8:29 pm
Yup
Blitz it with whatever germ killing concoction you have then get stuck in
Posted : 05/11/2021 8:43 pm
Overnight soak with Milton and it's good to go.
Posted : 05/11/2021 9:13 pm
Sealant post beating?
Posted : 05/11/2021 9:16 pm
Yeah, freezer is bloody pointless.
Use a weak bleach solution to clear it, then I use a denture tablet to every other week to keep it clean
Posted : 05/11/2021 9:21 pm
 feed
Mine has permanent black stuff in it, but it’s fine.
Barf.....
Anyway, Camelbaks are soooooo 2018, hip packs are sooooo 2019 \ 20. The cool kids these days are back to water bottles, bib shorts with stash pockets and shite strapped to the bike everywhere, and of course, long pants\slacks,t-shirt, no gloves regardless of the weather 🙂
If Milton is good enough for new born babies bottles, it will be fine for your bladder.
When you've finished it, clean it, empty it and hang it up on a camel back drying thing that's like a coat hanger for bladders. No need for a freezer.
Posted : 05/11/2021 9:28 pm
 pk13
Mine was black inside the tube Milton and turning a blind eye worked then my wife filled it with voddie and Coke for a festival that killed it
Posted : 06/11/2021 10:27 am
Denture tablets?
Is that basically the same stuff that Camelbak use in their cleaning tabs?  They are the only thing I've found that can get the taste of stale tea / coffee out of thermos bottles, metal or plastic.
Posted : 06/11/2021 12:14 pm
Yes
Posted : 06/11/2021 12:45 pm
