Jeht pilots and wat...
Jeht pilots and water bottles....
4 Users
Im injured and building up a Cotic Jeht with CC kitsuma shock.
The frame is a medium. Can anyone twll me what bottle/cage system works for the under top tube bottle mounts? There doesnt look to be much room with the shock piggyback in there.
Any help gratefully received
Ian
Posted : 01/08/2022 12:31 pm
Mine’s got a different shock, but I’m using a nukeproof side cage. Cotic recommended a Lezyne but the Nukeproof was cheaper. Using 600 ml wiggle bottle. Bit of a squeeze, 500 ml would be better.
Posted : 01/08/2022 1:32 pm
Ok thanks. I shall see how much room i can get. I should probably speak to Cotic too😀
Posted : 01/08/2022 1:49 pm
Lezyne cages are good, but Specialized Zee are lower profile (ie hold the bottle closer to the frame tube) if its close enough millimetres start making a difference
Posted : 01/08/2022 2:12 pm
I'm on a large with dB inline shock. Got a cheap zefal side load cage that was on my turbo trainer, surprisingly can fit an 800ml planet X bottle no problem. Survived Ardrock without it dropping out as well!
Posted : 01/08/2022 3:00 pm
