J spokes or straigh...
[Closed] J spokes or straight pull sopkes
7 Users
looking to get some pro 2 Evos on flow rims and wondered whether people thought one lacing method was better than the other. I know striaght is supposed to provide a tighter wheel but is this necessarily a better thing? I've heard rumours of people snapping more spokes due to them being so tight with a straight pull.
Posted : 09/01/2012 3:56 pm
Straight pull should be no tighter than a J type spoke arragement, just less likely to fail in theory. They require the same tension to keep the wheel in shape.
Posted : 09/01/2012 4:15 pm
Cheers.
I assumed the would be built with more tension therefore producing a tighter wheel as the spokes would be less likely to fail
Posted : 09/01/2012 4:50 pm
The rationale always seems to be that it does away with a weakspot at the J. But I don't think I've ever broken a spoke at the J, or seen one broken that way in the flesh. No doubt it happens but is it really a thing?
Main downer I found was that when I broke a straightpull spoke in fort william, there wasn't a shop in the area that had a single straightpull spoke. But then if you buy Hoops they should come with spares (at least mine did).
Posted : 09/01/2012 6:58 pm
All spokes will break eventually....so get ones that are easy to source.
Posted : 09/01/2012 7:00 pm
jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
available anywhere.
straight.
available (nearly)nowhere.
got a set of mavic classics hubs I'd like to rebuild.would already have done so if the spokes were easier to find/interchange.
Posted : 09/01/2012 8:28 pm
This. Yes Hope keep spares, but if you're not near a Hope dealer you're utterly screwed. J-bend can be had anywhere. I tried to track down a straight pull spoke for a Roval and the only shop I could find with a selection was one in the US who wanted $20 to post one spoke.
Posted : 10/01/2012 9:26 am
Incidentally njee20, Freeborn had them in stock when I needed them.
Edinburgh Bicycle Coop ordered some in for me, but being EBC they took 6 weeks to receive them, never told me they'd arrived, then sent them back after 4 days because I hadn't collected them. But I reckon they could possibly do better.
Posted : 10/01/2012 6:41 pm
 br
I bought the SP Crest's as they were lighter 🙂 and they come with spare spokes - they live in my tool box.
Posted : 10/01/2012 6:43 pm
Which is chuff all use if you snap one in the Alps 🙂
I'd not not buy a wheelset because they were straight pull, but I'd never opt for them.
Posted : 10/01/2012 7:15 pm
