It was with trepida...
[Closed] It was with trepidation and a pint of cider in me i ventured into shed...
5 Users
determined to make a Hope Expander cog designed to fit a Shimano free hub fit a Hope free hub, file in hand and cog clamped in the vice i hacked away expecting the worst only to come away victorious! Some times all that is needed is strong alcohol to make a bodge go well 😉
Posted : 14/05/2015 7:48 pm
Would that be a vote for Henry Westons then?
Posted : 14/05/2015 8:07 pm
Aren't Hope and Shimano freehub bodies designed to fit the same cassette cogs anyway?
Posted : 14/05/2015 8:13 pm
Spot on! still enjoying the effects...
Posted : 14/05/2015 8:14 pm
They're cut differently as i found out...
Posted : 14/05/2015 8:44 pm
What else did you have other than the cider?
Hope freehub said use the Shimano pattern.
Posted : 14/05/2015 9:06 pm
Ok, on the guide to buying the cog on the large website that i bought it from it gives you Sram or Shimano compatibility which i read as compatible with either cassett not the free hub. If you look at a Shimano free hub its ridges are rounded not raised squared off sections like Hope's. Thats why it wouldn't fit.
Posted : 14/05/2015 9:22 pm
Even when you're right, on the internet you're wrong. Perhaps 😉
Posted : 14/05/2015 9:49 pm
