Does anyone know of a blanking plate for ISCG-05, I'm not planning on using a chain device on my frame but don't fancy leaving the holes exposed to collect crud.
If you're actually serious, why not just tape them up, or put a screw in them, or use silicone sealant.
Erm, like a crank?
Just put bolts in them and you cant see it
You could weld the holes up and then get the frame powder coated so the bare metal is covered.
Or you could just leave it alone?
Put some bolts in them and that way you can use them again in the future if need be. You could even get colour coded bolts.
[url= http://www.ebay.co.uk/itm/like/231105611797 ]here you go[/url]
M6x5, Black, Nylon grub screws should be the lightest, cheapest way to [S]proove you are a tart[/S] bung up those holes...
On my bronson I bought one of these and then took off the bash guard and cut off the tabs that held that on.
http://www.chainreactioncycles.com/mrp-xcg-triple-chain-device/rp-prod31508
As when the chain did come off it got wedged down in the ISCG-05 tabs-which was a right pain ..
Now my chain never drops off onto bbshell area
