Is this shock worth...
[Closed] Is this shock worth fixing?
4 Users
 scuv
I've got this fox rp2 shock which is loudly sucking and blowing when in use but does work ok if a little slow. Are they worth fixing up or is this old shock now obsolete and easier to buy new? Is a self service easy to do on rear shocks and how much do the new parts cost?
Posted : 24/01/2015 7:31 am
All you can realistically do at home is unscrew the air can to clean and lube it ( something you should be doing as routine maintainence anyway).Anything more will require a full strip and rebuild, including a high pressure nitrogen charge, usually coming in at around £100 or so.
Posted : 24/01/2015 8:41 am
 scuv
Thanks for the advice just bought a proper full suspension bike and this is what was on it. I went ahead and bought a new one anyway which was £135, for that price it's definitely not worth a proper strip down service is it? I will be giving the maintenance a go though as soon as I check out some videos of it on youtube
Posted : 24/01/2015 6:10 pm
But is the new one the correct tune for you frame.Just to throw a spanner in like. 😉
Posted : 24/01/2015 6:36 pm
 scuv
I did double check on their website for the correct length and travel is that what you mean?
Posted : 24/01/2015 7:20 pm
Nope, he means is it the right damping (compression and rebound, and probably boost valve being a Fox) tune?
Posted : 24/01/2015 7:36 pm
 scuv
Hmm didn't realise there was options! I got a manitou radium. But I don't think this fox shock is the original that was on the bike when it was new either. It would have been a coil covered shock
Posted : 24/01/2015 7:39 pm
