Or am I overthinking it?
I was just browsing the Polaris site and came across this set of road bibs and top. It's pretty hideous, but on top of that the design reminds me a lot of 'Dazzle camouflage' which is used to fool the eye, and break up the silhouette of a target.
Wiki description of dazzle camouflage...
Dazzle camouflage, also known as razzle dazzle (in the U.S.) or dazzle painting, was a family of ship camouflage used extensively in World War I, and to a lesser extent in World War II and afterwards. Credited to the British marine artist Norman Wilkinson, though with a rejected prior claim by the zoologist John Graham Kerr, it consisted of complex patterns of geometric shapes in contrasting colours, interrupting and intersecting each other.
Unlike other forms of camouflage, the intention of dazzle is not to conceal but to make it difficult to estimate a target's range, speed, and heading.
Can you post a pic of them I can’t see anything?
Chapeau 😉
I agree its ugly but its not really dazzle camouflage. It is pretty uniform in layout which is the opposite of dazzle camouflage.
Plus I doubt it would work on something as small as a cyclist anyway. At least not without something covering the entire bike and deliberately distorting the bike shape.
Differing sizes of pattern, Zebra stripes on the arm, and blocks of black fabric on the sides of the jersey and shorts.
so you wouldn't be able to see them from a range of 2 miles from the gun sights on a Dreadnought?
fairly low risk.
as above, it's not dazzle camouflage it's a repeated pattern
and because we see photographs of dazzle ships in black and white we assume it was monochrome but it was incredibly colourful (the clue's in the name Dazzle)
4" alt="" />
so you wouldn’t be able to see them from a range of 2 miles from the gun sights on a Dreadnought?
fairly low risk.
That depends on where you commute...
That depends on where you commute…
Are who the rider is.
The idea of dazzle camouflage wasn't to conceal the ship, just to confuse the enemy about the range bearing of the ship to make gunnery difficult. I can't see how that has much relevance to cycling. And that's not dazzle camouflage anyway.
You're overthinking it. A lot.
You’re overthinking it. A lot.
Yeah probably, I do that.
The idea of dazzle camouflage wasn’t to conceal the ship, just to confuse the enemy about the range bearing of the ship to make gunnery difficult. I can’t see how that has much relevance to cycling
Yeah I know that, but anything that makes a cyclist more difficult to see or breaks up their silhouette is probably bad (which even if this isn't dazzle camo then I think this could do that).
Like roadies who wear just black, on black bikes & no lights?
Does it make them harder to see? Contrasting patterns generally help visibility. Dazzle camouflage fell out of use for this reason. As targeting equipment improved it lost what effectiveness it had and became a liability. So got replaced with pure camouflage.
Easy to see.
Difficult to see.
Roads are traditionally black. Drivers generally seem able to see them.
Anything that’s based on the premise of “you can’t wear this because people would like to drive their cars as quickly as possible and/or not pay full attention to what’s around them without having their day spoiled by someone else carelessly ending up on their windscreen” is a lot worse.
I like a bit of camo, but those designs are just nasty.
Does the top go over the bib bit or under like a set of dungarees? No bearing on the OP, I’m just curious?
Looks quite a bit like this
Which is pretty easy to see
Which is why a contrast between the road & the cyclist is maybe a good idea & I try to be easily seen. I don't want drivers thinking I'm part of the road.
It would be dangerous if you wore in a pub in Glasgow...nothing to do with the pattern though
I always think contrast is easier to see than fluorescent. Those white bands on solid colours for example break up the pattern . Anyway I use flashing front and rear light during the day.
Here's an experiment. Put the picture of the jersey on your phone screen. Prop the phone up at one end of a room. Stand at the other end of the room and look at the picture. Are you dazzled or does it just look blotchy / grey?
I put it to you that this is just a decorative pattern with no discernible visibility benefits.
With reference to hols2's pictures, I would change the captions.
1)Hard to forget.
2)Easy to look at at.
I agree with the OP. For me that breaks up the outline & makes it more difficult to see a ‘cyclist shape’ but you’d probably need to see it in the flesh to see how effective it is as camouflage. I don’t necessarily think you should be required to wear hi-biz, but I don’t think it’s a great idea to make things difficult for other road users. As an aside I’m not a big fan of black, but an all black cyclist is actually quite good at producing a solid, identifiable shape so is quite good for conspicuity. (Unless the light level is low.)
What's that ahead Margaret?
I'm not sure Roy... I think I can make out the shape of a bicycle, a pair of human legs and a head but the space in between... its like someone has opened a wormhole into a 6th dimension and where the body should be, there exists only a depthless void that has bedazzled my eyes and hijacked my visual cortex such that I can no longer determine the nature of the form before me.
I'm pretty sure it's just some chap with triangles on his push bike jumper Margaret.
No... Wait.. Oh yes so it is. How foolish of me.
"such that I can no longer determine the nature of the form before me."
From what I remember this, which you said sarcastically, is exactly what does happen.
Hence designs like this:
That's very clearly a plane. It's not like it's invisible because someone's painted a cockpit canopy on the underside.
Edit: With all the talk of dazzle camouflage, can everybody else see the car hiding in this photo?
“such that I can no longer determine the nature of the form before me.”
Indeed, the effectiveness of camouflage is well proven but unless you cycle in an environment dominated by the monochrome triangles then this specific pattern is not going to offer much is it?
If anything, covering a curved surface in a regular, contrasting pattern will make it easier to perceive the shape, not less.
An example of covering an object in a regular contrasting pattern in order to make it harder to perceive the shape:
Out of interest does anybody bother keeping an eye out when they are on the road to see what works and what doesn’t in terms of conspicuity? It never fails to amaze me in these sort of threads how much people seem to just trot out preconceived notions without ever once appearing to have to actually based the argument on the evidence of their own eyes.
Except that that is an irregular contrasting pattern. The idea is to make it harder for rivals to map the curved panelwork from photos, not to conceal the vehicle.
So if you happen across something you can't identify when driving your car you just think **** it and drive straight into it?
So if you happen across something you can’t identify when driving your car you just think **** it and drive straight into it?
That's pretty impressive actually. It took me a couple of minutes of hard staring before I realised it was a seagull and not a washing machine.
ajaj - it's still very VERY clearly a car. The only thing the pattern does is remove the brain's ability to perceive the 3D shape and contours. It doesn't break up the outline or make it less obviously a car.
The Definitive 11Foot8 Bridge Crash Compilation
Nah, I don't get it, I watched all* ten minutes of the video, still can't tell what's going on. Gonna have to go to the website to find out more.
it’s still very VERY clearly a car. The only thing the pattern does is remove the brain’s ability to perceive the 3D shape and contours.
It's still very clearly a car. The shadows and reflections hinder the ability of the pattern to confuse the brain.
