Is there not a 650b...
[Closed] Is there not a 650b 140mm Pike?
10 Users
I've just been looking at forks for the Orange 5 and can't see to find a Pike at 140mm.
Is it only a 29" variation?
Would the Yari be my only option of Rockshox? I don't want a 32 legged fork.
I'll probably stick with my 34's but I like to look.
Posted : 21/02/2016 1:12 pm
 P20
You can buy the longer 160 or 150 and replace the airshaft with a 140mm as far as I'm aware
Posted : 21/02/2016 1:19 pm
Only OEM, but all other 650b Pikes can be converted so just pick up whatever travel is available + an air shaft.
How old are your 34's? Put a FIT4 damper in them and they would be a much better fork for less than a whole new one.
Posted : 21/02/2016 1:20 pm
Buy 29" 140 pikes and fit 650b+ front tyre?
Posted : 21/02/2016 1:25 pm
 poah
buy the 150 pike and swap airshaft
Posted : 21/02/2016 1:34 pm
I prefer my Five with 150mm at the front...Just saying 😀
Posted : 21/02/2016 1:36 pm
+1 for 150mm and swap the air shaft, that's what I did. Works well.
Posted : 21/02/2016 2:29 pm
I've got one, they do exist in their pure form eg. no air shaft replacement. Do Chain Reaction not have any?
Posted : 21/02/2016 3:30 pm
As said above, they are normally oem
Posted : 21/02/2016 3:37 pm
CRC have 140mm but only in the 29" variety.
Like I say, only an idea at the moment. Most likely I'll stick with the 34's.
I'll keep an eye out for some 150mm Pikes though just in case.
Posted : 21/02/2016 3:43 pm
I've gone 140mm Pikes by changinng the airshaft on a set of 150's. Will ride for a while and put back to 150's for the summer when the riding gets bigger.
[url= http://www.chainreactioncycles.com/rockshox-pike-travel-change-air-shaft/rp-prod136305 ]Chain Reaction[/url]
3rd option down for 27.5 140mm. Easy to change.
Posted : 21/02/2016 5:31 pm
I'm tempted just to go 150mm. Seems most prefer the 5 at 150mm.
Failing that I'll go Yari's at 140mm.
Cheers for the link Andy. Very useful.
Posted : 21/02/2016 5:56 pm
 mrsi
As above, I went 150 to 130 via an air shaft swap. New shaft was about 30 quid and the change is very straightforward. I think MBR did a how to video which was handy.
Posted : 21/02/2016 6:05 pm
