Is there any differ...
[Closed] Is there any difference between 105 and cx-50, bar price??
8 Users
 DrP
I'm after a new crankset for the tripster, and apart from a big price difference (and the chainrings, but i'd swap mine over anyway), what's the difference between [url= http://www.chainreactioncycles.com/shimano-105-5750-compact-10sp-chainset/rp-prod50444 ]105 [/url]and [url= http://www.chainreactioncycles.com/shimano-105-cx50-cyclocross-double-10sp-chainset/rp-prod70118 ]cx-50[/url]??
Ta
DrP
Posted : 29/10/2014 4:28 pm
I think that the CX50 crank arms are the solid forged style like current Deore cranks(Basically just a stamped piece of alloy)
Whereas the 105 crank arms are the Hollow type the same as SLX upwards style cranks hence marginally lighter and stiffer?
Posted : 29/10/2014 6:46 pm
Correct.
I've just bought a CX50
I wish I'd just bought a Sora instead TBH
Posted : 29/10/2014 7:27 pm
 DrP
Why's that pete??
I'm planning the same FSA -> shimano swap you did (for the "poor mans inbred" 😉 )
DrP
Posted : 29/10/2014 9:10 pm
Because it's virtually identical as far as I can see but the Sora is cheaper and has a 2t smaller inner ring. I ordered a CX50 because I thought it had hollow arms. I was wrong. I'm not too bothered though, it only cost me about £15 including an Ultegra BB after selling off the new FSA. Looks nice too, fits in well with the CDF.
Posted : 29/10/2014 9:39 pm
DrP - I'm selling a black 105 chainset with 175mm cranks and compact rings. Very good condition, little use if you're interested.
Posted : 29/10/2014 9:46 pm
Chainrings not any different, no?
Posted : 29/10/2014 10:08 pm
I've got both, the cx 50 has solid arms the 105 has hollow arms
Posted : 29/10/2014 10:10 pm
 DrP
Well as a tart I went for the 105 due to the hollow arms/weight etc..
Will swap the road chainrings with the FSA ones that came with the tripster.
Means I can also run a shimano BB with 22mm spindle, rather than the odd FSA 19mm one...
DrP
Posted : 31/10/2014 9:10 am
+1 CX50 is solid. And heavy. Go 105.
Posted : 31/10/2014 9:13 am
