Is shimano 12 speed...
[Closed] Is shimano 12 speed cassettes creaking at the rivets a thing?
11 Users
Desperately trying to silence cassette, got through multiple removals, cleans, greases and lockrings, I can't get it to shut up. Yep, have the plastic washer installed. It's definitely tight, barely any indents fron the loose sprockets.
The only thing I can think of that's left is creaking at the rivets between the sprockets and carriers, anyone had this?
Posted : 21/08/2021 9:53 am
It's not your cassette (probably). Can you swap it for another to check..?
Posted : 21/08/2021 10:22 am
Is it an old chain on a brand new cassette?
Posted : 21/08/2021 11:58 am
Cracked alu freehub body?
Posted : 21/08/2021 12:02 pm
About 6 week old chain and cassette.
Inspected freehub.
Can get the cassette to creak off the bike with a chain whip. Poking fingers in everywhere when I get it to creak, strongest in cassette. only occurs on cogs which are on the carrier.
Posted : 21/08/2021 12:18 pm
Sounds like you've done about as much as you can diagnostically. Maybe drip some oil at the rivets while making it creak just to confirm but sounds like the only cure is a new cassette.
Posted : 21/08/2021 12:31 pm
What washer? This is a worrying development!
Posted : 21/08/2021 4:02 pm
Washer was a separate piece on XTR but is integrated in XT.
Posted : 22/08/2021 4:00 pm
It happened on my 11-51 deore cassette (11sp) rivets came loose. Replaced under warranty
Posted : 22/08/2021 4:47 pm
My creaking on drivetrain came from my front chainring bolts and fiddly locking attaching front chainring to the cranks
Posted : 22/08/2021 5:49 pm
Very thin plastic washer at the back of the cassette where it meets the free hub. Designed to stop creaking according to Shimano. I think on newer cassettes it’s actually stuck onto the back of the cassette now rather than being loose as I think so many people were losing them…
Posted : 22/08/2021 7:42 pm
Soaked the rivets in penetrant oil overnight, creak is so bad now.
Posted : 22/08/2021 7:49 pm
Creaking like this?
If so you need some grease on the weird plastic thing in the hub. Not hard to do
Posted : 22/08/2021 7:52 pm
 jedi
My xtr cassette creaks like **** if dusty. Does my nut in
Posted : 22/08/2021 9:44 pm
