Is online route pla...
[Closed] Is online route planning
5 Users
Does this always plot routes in straight lines rather than follow actual route of bridleways etc.? It seems to to me
Posted : 10/07/2021 9:56 am
No. The OS App has an option to follow rights of way within national parks. It occasionally misses a connection node but I think it's brilliant.
( Had previously used Viewranger and another on the past )
Posted : 10/07/2021 9:59 am
What app are you using to plan online? I use Strava and its pretty good at showing paths and off road routes. There's a manual function too so you can plot your own path if you know its there.
Posted : 10/07/2021 12:05 pm
I generally use cycle.travel which follows paths, etc. Plotaroute has the option to turn following off if required.
Posted : 10/07/2021 12:18 pm
Sorry - title should be OS (Ordnance Survey) route planning......
@ the generalist - so OS only follows rights of way in National Parks?
thanks
Posted : 10/07/2021 2:03 pm
I think the new OS maps web version isn’t restricted to national parks and is probably quite good if plotting from scratch, but I’ve found it sub-optimal when importing routes to edit.
Posted : 10/07/2021 7:23 pm
