Is my frame on its ...
[Closed] Is my frame on its way out?
4 Users
I removed a bottle cage from my carbon road frame at the weekend. When I put the bottle cage screw back in the threaded insert in the seat tube began to spin. The threaded insert/bolt now spins in the frame. I can't see any major cracks, although the paint/lacquer has come of off the threaded insert.
Is this a sign that there's more serious problems afoot, or just the threaded insert worked lose.
Posted : 21/04/2014 11:22 am
If its a size medium I'd say its probably dangerous. Send it to me for safe disposal.
If its not then I'd say its perfectly safe..
Posted : 21/04/2014 11:29 am
It's fine. You can get the old bottle mount drilled out and a new one inserted.
Or you could just drop some strong glue around it to stop it spinning.
Posted : 21/04/2014 11:40 am
Its just a rivnut isnt it? I would just put a spot of glue behind it.
Posted : 21/04/2014 1:22 pm
