Is my brand new Sra...
[Closed] Is my brand new Sram eagle derrailerur goosed?
5 Users
New out of the box and installed on the bike, there's a s*it load of play in it at the bolt mount end, also when shifted all the way in it doesn't line up with the 50T gear, it looks to line up with about no2 gear.
See this video here for the amount of play I'm talking about.
YouTube vid
And another video here
YouTube vid
Posted : 03/11/2019 6:09 pm
You need to adjust the limit screws to get it to line up and that play is normal
Posted : 03/11/2019 6:16 pm
With the cable removed from the mech it lines up bang on with the 10T cog where it should (centre to outside as per sram youtube videos)
Then attach the cable and trigger the shifter up to the 50T cog and it's a good 2mm off the centre of that big cog (between 1St and 2nd gear)
In essense there is no need for limit screws on this mech as it doesn't have the available movement to throw the chain off either end of the cassette.
The only way to line it up with the big cog is to wind on the cable tenstion at the barrel adjuster but then that screws with the allignment at the 10T cog!
Posted : 03/11/2019 7:37 pm
Default question is - have you checked or are you sure the Hanger is straight?
Posted : 03/11/2019 7:51 pm
Is your frame direct mount and you’re mounting the mech with the extra link still attached? Just a thought as I did that initially when replacing a mech once and it wouldn’t move all the way across as the extra link made it sit in the wrong position.
Edit, just realised direct mount is shimano not sram.
Posted : 03/11/2019 8:03 pm
In essense there is no need for limit screws on this mech as it doesn’t have the available movement to throw the chain off either end of the cassette.
I suggest that you either read the installation instructions or go and get a bike shop to set it all up for you.
Posted : 03/11/2019 9:22 pm
