The mrs has decided (after a little accident) that she doesnt like nor need the big ring on her bike and wants one of "those plastic things that stops you geting spiked" hence move to a 2 x 9 setup.
So excuse the numpty question as I'm just settling in but can I just remove the outer ring and replace with a bash guard (I know I'll have to setup the front mech so it doesnt shift etc) and job done?
I was thinking of Something like this
http://www.chainreactioncycles.com/Models.aspx?ModelID=50668
She has a Boardman Fi with a Truvativ GXP crank.
Or is it a little more complicated than that ie would I need to fork out for a new crank
It really is that simple
Might want to shorten the chain a bit too.
Certain bash rings are thicker than chainrings and need longer chainring bolts though.
She might be undergeared and need the 32t ting swapping for a 36t in the future, so get a 36t-sized bashring in the first palce and you're covered! 🙂
Cheers guys thats exactly what I wanted to hear.
PP good point I did think about going 34t as she's only wee with little legs and thought 36t may be a bit much for her then leave the inner ring as 22t.
5Lab thats an even better idea and a bit cheaper too as I already have one 😆
i was nervous about doing the same conversion myself (being new to mtb's, riding and mechanics of a bike) but it really was that easy. i had to order longer chain-ring bolts (about 4quid from crc) and did it at a friends who has multiple allen keys 😀
not missed the big ring once and haven't cut my beautiful legs up since!
Tell her to man up, man.
BBG Bashguards.
In principle it's extremely simple. However there are a couple of things you need to take into consideration:-
1) Will she miss the lack of a large chainring? If so, then you'll need to budget for either a 34-36T middle ring.
2) The bashring should be large enough to cover the largest chainring remaining. If she's left with a 36T middle ring, then the 26T bashring on CRC will be left with a lot of overlap.
You can pick up a slimline Truvativ bashring which doesn't weigh much and does a good job of protecting the chainring from logs, legs and rocks.
Do not be tempted to lower the front mech though. The hollows and profiles are designed for each ring so it will rub if you do.
very much more complicated than that!!
Send me £100 and I'll tell you the secrets
