Is it okay to mix m...
[Closed] Is it okay to mix mineral oil?
7 Users
 PJay
My SLX brakes seem to be working without issue, but I have notice that if the bike's been up side down whilst fixing a puncture on a ride, the levers seem to need pumping up again to firm up; I guess that there's some air in the system (possibly from when I cut the hoses without re-bleeding).
I'm got some Shimano mineral oil (it's several years old but I believe that it doesn't deteriorate or absorb water) and I was wondering whether it's okay just to top up the system from the lever and pump out any bubbles into the bleed funnel, instead of doing a full bleed. Will there be any issues mixing different (and one quite old) batches of Shimano mineral oil?
Posted : 12/09/2016 5:39 pm
It'll be fine. I wouldn't mix different brands though (or use anything other than shimano oil in shimano brakes)
Posted : 12/09/2016 5:42 pm
It'll be fine, that's what I normally do instead of a full bleed.
Posted : 12/09/2016 7:22 pm
 PJay
Thanks. I need to change the brake pads shortly,so I'll do it then.
Posted : 13/09/2016 5:41 am
Unlike DoT fluid, mineral oil is not hygroscopic. So your "aged" shimano brake fluid should be fine.
If the fluid that comes out is black/dark and you've got enough fluid it's worth doing 2 full bleeds.
I've also found if you leave the brake lever tied on, it encourages air bubbles up to the top of the system. I tend to leave mine "on" for an hour or so. Before i snip off the cable ties I tap the caliper, and then up the brake hose to the lever. I usually get a number of smallish bubbles come out then and the brake feels a lot better. You can also slightly undo the lever clamp (with the pot atached to the lever) and roll it back and forth -+45 degrees whilst flicking the lever to encourage any bubbles out.
Posted : 13/09/2016 7:14 am
So am I risking killing kittens when I use citroen LHM?
Posted : 13/09/2016 7:27 am
i raised a similar concern when shopping at my LBS for mineral oil for my xtr's - they sold me aftermarket oil - I bought the brakes from them - and they assured me it wouldn't effect the guarantee despite Shimano clearly stating only use their own branded oil ..
Posted : 13/09/2016 7:32 am
Have search on here for an older thread. Many people (including me) stating they used a "compatible" mineral oil but the brakes don't feel as good.
The compatible stuff I used (from halfords i think) is more viscous giving the lever a different feel. Also there is a chance the oil may react with the seals causing them to swell up.
Posted : 13/09/2016 10:00 am
This^^^
Shimano oil is a lot thinner. Mineral oil is such an ambiguous term, like having a cold.
Shimano mineral oil has a significantly higher BP than, other brands. Used some cyclo stuff (green) in my brakes last year in the alps and it was burned up after about 3 runs.
Posted : 13/09/2016 10:06 am
