Struggling to set up my Giant wheels. The front was ok but the rear will need a bit more violence.
My Stan's wheels go up just like there is a tube in there.
In my mind a wheel set and tyre combination that needs the head breaking when you let the air out must be better than one where the tyres naturally fall into the centre.
I'd like a physical connection rather than just relying on air pressure.
I think you're right (no science).
when you inflate them and put your stans in pressure to 40psi to male sure there well seated and leave overnight then let down to 20psi. This makes sure they are well seated. Stans rims are brilliant they go up so easy. Never had issue with tyres coming off the rims even below 20psi.
