Internal rim width ...
[Closed] Internal rim width for a 29er rigid fork?
2 Users
30mm? 35mm?
This is a spesh Chisel with the Selcof Carbon forks from PX
I'm on a 25mm rim with Spesh Fast Traks 2.3. I'm getting roll of if I run a pressure that helps with the judders. So I want some bigger tyres.
The only experience I have with tyres beyond 2.4 is the 2.6 that came onmy Canyon Spectral. The rear had a 2.6 Rekon and even on the 30mm DT rims, that rolled a lot at softer pressures.
If anyone has any pearls of wisdom regarding the sweetspot for a fastish tyre/rim combo for a rigid 29er front end... I'd love to hear.
Hope you're all well.
Posted : 08/06/2020 11:15 am
I have a rigid fork, I have rims with I think about 25mm ID. I use Schwalbe Racing Ralphs at down to 20psi and I don't get any roll in corners. I usually run a bit higher if I have lots of road to do (23psi) because I get bouncing on pedalling. 20psi is the best pressure to deal with rocky Welsh trails.
I used to use the Specialized Slaughter/Butcher combo (non-Grid) and these were terrible for bouncing and rolling, I had to run 30psi. So I think that Schwalble tyres have much more supportive sidewalls than the Spesh ones did. I use 2.2 Rocket Rons on my FS XC bike on narrow XC rims and they only need 25psi to behave well.
I'm no whippet either at 90kg and I don't mince the descents.
Posted : 08/06/2020 11:31 am
