Internal cable rout...
[Closed] Internal cable routing on a steel frame without
5 Users
I'm planning on getting the new singular swift in November. What's the most professional way to do internal cable routing. No rattle would be perfect. Its a steely.
Posted : 07/10/2013 3:12 pm
It's just too much faff for very little gain really. You'll need to go to a frame builder to get it done for a start. It not just a case of drilling a few holes in the frame you know! You'll need internal cable stops fitting. Then you'll be cursing every time you need to change a cable too
Posted : 07/10/2013 3:33 pm
I'd talk to Sam before drilling any holes in the main frame tubes.
Posted : 07/10/2013 3:34 pm
There are several ways of running internal routing - I'm not a big fan of the internal stop design, it causes too many problems in the real world and is a nightmare to fix. So when I do it I always run full outer all the way.
Posted : 07/10/2013 3:54 pm
'no rattle'.
Mine doesn't rattle. Unless you're desperate to do it, I really wouldn't bother.
Posted : 07/10/2013 4:06 pm
I'm minimalist. Suits my needs. I will be running cable discs if that helps.
Posted : 07/10/2013 4:25 pm
The only really professional way is to send it to me* and I'll fit guides or internal tubes as you prefer.
*other framebuilders are available.
Posted : 07/10/2013 4:27 pm
