Whilst looking for a RAM mount for my Etrex 20, after giving up on the zip tie mount. I came across this -
http://www.thingiverse.com/thing:164720
Anyone seen this before and has anyone tried it? Tempted to get one printed from a 3D online services.
Anything has to be better than the current Garmin offering! Pretty certain I started a thread to moan about it.
Damn i was hoping you could but that as the garin version is gash
Does not secure the GPS to it
Does not secure itself to the bars
It has two functions and does neither of them
If anyone here can print it i would be interested in a couple of these
I agree, Garmin version is terrible. I'm interested in one but it needs slightly changing to 31.8mm bar mount, unfortunately I don't have the skills.
I've heard many grumbles about the garmin mount but have always found the three I have to be fine. Never ejected the gps, stays in place - on stem and bars on different bikes.
I wonder if there are fakes about?
I've heard many grumbles about the garmin mount but have always found the three I have to be fine. Never ejected the gps, stays in place - on stem and bars on different bikes.I wonder if there are fakes about?
Bought mine from Garmin. It fell off, zip ties a rubbish idea for an expensive gizmo.
Moaning woman:
http://singletrackmag.com/forum/topic/garmin-etrex-30-bike-mount-removal-woes
I believe an adapter to Garmin quarter turn is a better solution: https://www.amazon.com/Rec-mountsTM-Handhelds-eTrex%C2%AE30x-Touch35t-GM-GHG/dp/B017G5458E
*some modding required, as this adapter has 4 tabs instead of 2.
Bit bulky and damn expensive for what should be fairly easy for Garmin to rectify.
@cinamon_girl
Sorry which printed one do you think is better, the one with the lever as in the OP's picture or the other ?
[quote=Kamakazie ]Bit bulky and damn expensive for what should be fairly easy for Garmin to rectify.
Massively expensive
It such a shame the Garmin one is shit considering the other out front one are good
I assume i will need to get the RAM version and bodge that.
Like I say, have heard many complaints but all of mine have been fine for c. 10,000km of off road riding over the last year or so.
Mines are all zip tied on. They haven't fallen off. I do have the device on a leash just in case...
Just to add that if you have longer slide rails then there is no need for the sticky out bit in the OP's pic.
I believe an adapter to Garmin quarter turn is a better solution: https://www.amazon.com/Rec-mountsTM-Handhelds-eTrex%C2%AE30x-Touch35t-GM-GHG/dp/B017G5458E <
Might attach to the handlebars better but still looks like the same mounting for the Garmin, so will still come loose from the mount itself.
Bump for anyone with a 3D printer who would be kind enough 😆
There are cheap chinese copies around for about £3/4 on Amazon,etc, these are the shit ones with the 'noggin'/protrusion at the bottom which is not deep enough. The Garmin boxed ones from Wiggle etc for £8+ all work fine.
