What are the chances of getting a couple of uplifts on a sunday avo?
try www.upliftscotland.com Tallys your man
You might be lucky and get a couple of single runs. £5 per person per run.
There's usually spaces late in the day, it's mostly about how many people are after them (and how well they know the crew!). It does end quite early though, the switch away from the bus-and-truck has sped up the runs but it still starts at the same time.
We are down a lot and there are always spaces first thing in the morning
can normally get at least one run first thing maybe 2 depending on when people managed to arrive. its a 45-50min trek up to the top otherwise
I had a Saturday uplift booked a few weeks ago and had some much that we went back on the Sunday morning. Managed to get four runs in before some stragglers appeared. if you're on your own you can probably get a few more in, but if there's a few of you then it's less likely.
