Inexpensive, reliab...
[Closed] Inexpensive, reliable rear hub ....
16 Users
Looking at 135mm spaced - none of this silly boost/boost plus stuff 🙂
I would default to Hope but thought I would ask.
Any suggestions?
Posted : 28/06/2017 5:54 pm
SRAM X7 - not as light as a hope but they were £35 from one of the online shops in Germany
Posted : 28/06/2017 5:57 pm
inexpensive and reliable has to be shimano don't it? Not that I like them personally but value for money is good and reliability high
Posted : 28/06/2017 6:02 pm
deore rear hub £17! or for a bit more XT £36.
 P20
Novatec from eBay?
For inexpensive then SLX. Good old cup and cone 1/4" bearings, strip, fill with grease and properly adjust before you start and you're good to go! £40 rrp, with a decent skewer included. Add a centrelock adaptor/rotor and you're still pretty cheap.
Posted : 28/06/2017 6:10 pm
Novotec
Posted : 28/06/2017 6:12 pm
go default. Rear hubs have a hard life.
Posted : 28/06/2017 6:20 pm
Shimano every time.
Add a quick blob of good grease and check the cones for tightness/adjustment BEFORE USE and they last forever. Plus they cost buttons to service.
Posted : 28/06/2017 7:11 pm
Yep, can't look past Shimano.
Deore / SLX / XT depending on budget
Posted : 28/06/2017 7:29 pm
I've had a few formula based wheelsets that have caused me no trouble.
Posted : 28/06/2017 8:24 pm
The best hubs are DT Swiss. The 350 is a bit over £100 though, so not super cheap. Cheaper and better than Hope though.
Posted : 28/06/2017 8:31 pm
Worth buying above Deore, the seals are way better.
Posted : 28/06/2017 8:32 pm
Are all Shimano hubs still loose bearings?
Posted : 28/06/2017 8:34 pm
Yup
Posted : 28/06/2017 8:38 pm
Cheers. Got some Zee/XT wheels coming for my 26+ adventure. Must remember to strip and pack before use then...
Only ever used cartridge bearing hubs before.
Posted : 28/06/2017 8:39 pm
colournoise - Member
Can I be nosy and ask what adventure your undertaking? 🙂
Posted : 28/06/2017 8:59 pm
Metaphorical adventure rather than physical.
Just going to try 26+ in my 650b Rocket...
Posted : 28/06/2017 9:00 pm
Ah,I see mate! 🙂
Posted : 28/06/2017 9:08 pm
